Results 1 to 4 of 4
Thread: silverface super reverb - 4 ohm output?
    Apr 2008
    Croatia
    51
    Is this a mistake - this schematic shows a 4 ohms load for late seventies super reverb:
    http://www.webphix.com/schematic%20h...-bmstr_rev.pdf
    Senior Member Enzo's Avatar
    Lansing, Michigan, USA
    18,069
    What do you think it should be?
    4 ohms to the main jack. Plug anything into the extension jack, and the contacts switch over to the 2 ohm winding. That way the internal 4 ohms and the external 4 ohms - which combine to make 2 ohms - will be served.
    Apr 2008
    Croatia
    51
    Thanks Enzo, if I only bothered to previously look at the back of the amp - it says ''4 Ohms'' - I thought that all Super Reverbs work on 2 Ohms...
    Supporting Member
    Jul 2007
    So. California
    880
    That's the UL version. You can see Fender used the same amp for the Super, Pro and Bandmasters (reverbs). The Super reverb used four 16ohm speakers, unlike earlier ones with 8 ohms.
  1. How can I use a 4 ohm output amplifier to 4 8-Ohm speakers cabinet.
    By custom_amp_30 in forum Music Electronics
    Last Post: 05-29-2011, 12:50 AM
  2. Replies: 6
    Last Post: 03-14-2011, 01:19 PM
  3. super reverb output values, please
    By JC@ in forum Maintenance, Troubleshooting & Repair
    Last Post: 03-07-2011, 01:33 AM
  4. switching 8 ohm to 4 ohm output-output power reduction??
    By pintail78 in forum Theory & Design
    Last Post: 09-09-2010, 07:46 PM
  5. plugging 8 ohm speaker into super reverb
    By drf46 in forum Maintenance, Troubleshooting & Repair
    Last Post: 02-13-2010, 07:07 PM
