Results 1 to 9 of 9
Thread: Spirit Folio Notepad
    Jul 2009
    77
    I have just bought a Notepad for literally pennies, the reason being there is no PSU. Can anyone tell me what the +- voltage and current is, and is it possible to use two wall warts, one + one - instead of building a new PSU. From what I can see the PSU for this model is no longer available and even if it was judging by the price of other folio Psu's, way out of my range. Help appreciated. Happy Xmas.
    Dave.
    Noodle of Reality Steve Conner's Avatar
    Glasgow, Scotland
    7,251
    Did you try looking for the manual on the Soundcraft web site? The power supply spec might be in there.
    Don't know if the Folio is still in production, but the site has a "discontinued products" section.
    I bet + and -15v would work.
    Jul 2009
    77
    Thanks Steve, I have a couple of Variable psu's that go to 18vdc. Dyou reckon they would worklike I said 1 at 15+ and one at 15-. cheers Dave
    g1
    g1 is offline
    Feb 2010
    9,156
    Apparently it uses 36VAC centre-tapped at 600mA. You should be able to hook up a split DC supply internally after the rectifiers but the 48V phantom supply is derived from the AC voltage so you will lose that.
    Certified Dotard
    Jul 2009
    77
    Thank you g-one, forgive me if I sound bit dumb but I take it what you mean is I just need a 240 volt transformer with 18-0-18 secondary??
    Thanks, Dave.
    g1
    g1 is offline
    Feb 2010
    9,156
    Yes, that's what it would be. As long as it's good for 600mA. You will have to figure out which of the connector pins is the ground.
    Certified Dotard
  7. #7
    Jul 2009
    77
    Thanks G-one, have a good Christmas.
    Dave.
  8. #8
    Jan 2012
    16
    Hi, I have a spirit folio F1 14/2 mixer, It uses a psu which diplays on the case that it puts out 17.1v - 17.1v - 0v, all ac, however I tested each core and got readings at 38v - 18v - 0v... I guess soundcraft are trying to ensure no one can replicate this for some reason..?
    Hope this is useful to you.
    Dan
  9. #9
    Lifetime Member Enzo's Avatar
    Lansing, Michigan, USA
    28,879
    You are just reading the pins in the wrong order.
    A 17 - 0 - 17 VAC means from the center tap there will be 17v to either end. If you start with one of the end pins you will get 17 and 34v.
    Put your meter on the pin that gave you 18v and measure the voltage from there to each of the other two pins. I bet you get about 18v each way.
  1. spirit powerstation 600 schematic needed
    By plec.22 in forum Schematic Requests
    Last Post: 07-30-2013, 06:57 AM
  2. Soundcraft Spirit Live 3 Mkii
    By ne0 in forum Schematic Requests
    Last Post: 04-08-2011, 08:07 PM
  3. Soundcraft Spirit Folio Lite quality?
    By dai h. in forum Music Electronics
    Last Post: 01-25-2010, 01:05 PM
