Results 1 to 20 of 20
Thread: Strange results with Seymour Duncan Jimmy Page wiring mod
    Dec 2011
    41
    This is a bit of an embarrassing one but I need some help with the wiring I just did on my Les Paul copy. I followed the Seymour Duncan diagram.. http://www.seymourduncan.com/pdfs/su...s/jp_style.pdf
    When originally wired up, I followed it to the exact detail.. plugged in, and I got really bad ground hum that was cancelled out with me touching strings/bridge etc. So, I linked the pot casings from bridge vol - neck vol - neck tone - bridge tone. This seems to have sorted out the ground hum. Almost.
    Another problem is the volume pots don't seem to be grounded properly as when set to zero there is bleed through of the guitar. The volume pots are grounded from lug to casing. Also, when the bridge tone switch is pulled for out of phase, the ground hum is back. All ground connections check out with a DMM.
    Lastly, when the neck tone switch is pulled, for series wiring.. if you select the bridge pickup, it is muted - or at least would be if there wasn't the grounding issue I outlined above. Is this part of the deal? I realise that series wiring is useless without both pickups selected.. but if I wanted to switch from middle position in series, to bridge alone, I would have to push the neck tone pot and flick the pickup selector. Hardly a practical design!
    Any ideas before I start from scratch with a different diagram? I checked all my wiring and it seems good to me, no mistakes that I can see. I've wired up plenty of guitars, but this is my first attempt at anything as complicated as the JP wiring.
    Dec 2008
    Wernersville, PA
    12,105
    Man, that is one confusing wiring diagram.
    The switch positions are not indicated.
    There is not a path from the pickups to the pots.
    Is there an actual schematic available?
    Dec 2011
    41
    Not sure about a schematic, there are quite a few different diagrams out there if you do a quick google search. So this seems to be one of those things where there are many ways to skin the same cat, whether a schematic would even match up to this diagram is doubtful.
    Dec 2011
    41
    Just found this... Les Paul Jimmy Page wiring with 42 sounds
    Scroll down until you find two images together. They're the complete diagrams. They look really confusing too though!
    Dec 2008
    Wernersville, PA
    12,105
    Well. here is a schematic that I found.
    It is a bit more illustrative, as it shows the switches.
    Attached Files Attached Files
    ToneOholic! big_teee's Avatar
    Jun 2010
    Mid-South USA
    10,539
    Quote Originally Posted by Jazz P Bass View Post
    To Damn Complicated for me!
    I would forget that the Primary Objective was to Play Guitar!
    B_T
    Technicians Run the World, but Bankers, Lawyers, and Accountants, Take All The Credit!
    Keep Rockin! B_T
    Terry
  7. #7
    Pickup Maker David Schwab's Avatar
    Staten Island, NY
    10,945
    Quote Originally Posted by big_teee View Post
    So then play a guitar with one pickup and no controls if it's that confusing! Or better yet, an acoustic guitar! Then you don't have to worry about knobs and tones and stuff.
    To the original poster. You say the pots have the ground lug soldered to the back (can) of the pot. Do you also have aground wire attached from that to the output jack's ground? Duncan doesn't show all the pots connected to ground, but they have to be. You can run a wire from one pot back to the next and then one of them can go to the jack's ground.
    http://coneyislandguitars.com
  8. #8
    Jun 2010
    Mid-South USA
    10,539
    I like controls, and Pots and Stuff, but 4 Pots, and 4 Push Pulls is IMO a little much.
    I have done some 4 POT and 2 Push Pulls.
    You can get split and Phase reverse wit that.
    Anyway have fun with JP Design.
    T
    Keep Rockin! B_T
    Terry
  9. #9
    Staten Island, NY
    10,945
    T
    I think it's over kill myself, but you don't have to use it all.
  10. #10
    Dec 2011
    41
    David.. Yep, I have a ground wire from the back of the pots to the sleeve of the output jack. I'm puzzled. I don't understand why Seymour Duncan don't link the pot casing together with a ground wire.
    I'm just gonna attempt a different diagram I reckon, the one I posted above that was designed by a forum member looks too unclear to me.. Too much potential there for mistakes.
    It is overkill, but it's interesting! So many options, so many different sounds.. Why wouldn't you want that?! It's like an artist having as many colours as possible on his palette.
  11. #11
    Staten Island, NY
    10,945
    Quote Originally Posted by sickman82 View Post
    Oh believe me, I've done stuff like this in the past. Back in '76 I had six toggle switches, a rotary switch, and five knobs on my '73 Rick 4001 bass! I had a phase switch, series/parallel, and series/parallel for each pickup (humbuckers). Then I had a six position Varitone midrange choke. The next year I added a preamp with active bass and treble controls.
    What I found after a while was a lot of good tones, and even more similar or useless tones. Some would translate to guitar better, such as the out-of-phase stuff. I had something similar on my guitar.
  12. #12
    Dec 2008
    Wernersville, PA
    12,105
    Aahh, but it is indicated.
    There is a small box that shows a solder blob, with solder marked in it.
    They specify that all markings of this nature are to be grounded together.
  13. #13
    Dec 2011
    41
    That's unusual though, usually they have those blobs linked with a wire as you would expect. I had missed that though, thanks for pointing it out. By 'location for ground connections' do they mean ground together?
    David, that picture is amazing! I love it.. that bass, I bet it roared! Look at all the knobs! You still have it?
  14. #14
    Staten Island, NY
    10,945
    I do! St that time it has a Carvin humbucker at the neck, and a Hi-A pickup at the bridge. A bit later I added a DiMarzio Model P between them and put the Toaster back into the neck position. Bt I left the larger hole in the pickguard and made aluminum brackets so I could get the toaster closer to the strings.
    Here's a very funny 70s photo of the bass:
    I started doing a lot of work to it after that. I wanted to make it like a 4004 Rick, although they weren't out yet, but it was the same idea. So I filled in all the cavities, and put a maple top on it. I also made it a lined fretless. I never finished the work and it's been in tat state ever since. I'm going to finish it soon. My other bass got painted burgundy mist metal flake, and gor the Hi-A from the first bass and then later a Gibson mudbucker at the neck.
    Here's the two basses as they are today. I'm going to restore the purple bass and make it Jetglo.
  15. #15
    rjb
    rjb is offline
    Feb 2010
    Somewhere near Bawlmer, Merlin
    2,455
    Quote Originally Posted by David Schwab View Post
    Until you need to amplify it.
    In a former life, I used to produce folk music concerts.
    You'd be surprised how much gear some acoustic bands "require", compared to a typical rock and roll setup.
    Later,
    -rb
  16. #16
    Jul 2008
    Sunny Tampa, Florida
    538
    Quote Originally Posted by rjb View Post
    Nevermind that they also tend to be in a state of near denial about it and either pay no attention to it except to insist that everything be both perfect and someone else's problem or that whatever gear they happen to have bought has to be just right because it was highly recommended.
  17. #17
    rjb
    rjb is offline
    Feb 2010
    2,455
    Way Off Topic
    Every acoustic guitarist needs one of these. Download your "acoustic images", then change your guitar's body size & shape, tonewoods, and virtual microphone with the twist of a dial. Or something like that.
    Aura® Spectrum DI - Fishman Transducers, Inc.
    -rb
  18. #18
    Dec 2011
    41
    Not being one to leave a thread open ended, I thought I should tell you lot what happened in the end with the wiring.
    Apparently the Seymour Duncan scheme is incorrect, there are many others that have had the exact same issues. I managed to find a different scheme that was wired up 50's style too.. Nice. Works a treat, no noise when turning volume down, no dead position on the selector switch.. But the same buzzing problem when not touching the strings!
    Again, it apparently isn't unusual.. There's too much going on in the cavity it seems and it all amounts to a fairly noisy wiring layout. I'm gonna live with it for now, I shielded the main cavity and switch cavity which helped a little. I'm enjoying the tones too much to give it up, a bit of buzz don't bother me!
    Thanks for all your input.. If anything, I enjoyed your photos David. Cheers!
  19. #19
    Jun 2010
    Mid-South USA
    10,539
    I know your trying to close this out, and not leave an open end, but!
    Wanted to add, that rewiring the guitar with good Insulated shielded wire(small Shielded Cable) is a good place to start.
    I always rewire from the Jack to 3 Way switch with a small insulated shielded cable.
    Then I use another insulated shielded cable from 3 way to the controls.
    That alone always seem to quieten down a LP Guitar.
    That along with good quality switches, and Pots.
    Then inside the control cavity I usually just use wire, and try to keep all Lead lengths short.
    Good Luck,
    Terry
    Keep Rockin! B_T
    Terry
  20. #20
    Dec 2011
    41
    Yep, that would be the next thing I'd try. I've got some 3 conductor shielded cable I use for pedals, so if it sounds too bad at my new band's first jam session this Friday, I'll sort that out.
  1. Les Paul Jimmy Page wiring with 42 sounds
    By Borsanova in forum Guitar Tech
    Last Post: 01-23-2017, 04:45 PM
  2. Seymour Duncan SA1
    By Sock Puppet in forum Pickup Makers
    Last Post: 11-16-2009, 11:34 PM
  3. Jimmy Page Mod?
    By Lexotron in forum Guitar Tech
    Last Post: 08-29-2008, 05:00 AM
  4. Pseudo Jimmy Page Modification
    By 13eastie in forum Guitar Tech
    Last Post: 07-26-2008, 04:58 PM
  5. seymour duncan timeline
    By dazzlindino in forum Pickup Makers
    Last Post: 03-19-2008, 05:18 PM
