Results 1 to 5 of 5
Thread: PT Current Capactiy Rating for 5F11 Vibrolux
    Nov 2007
    Columbia, SC
    409
    Im in the process of building a 5F11 Tweed Vibrolux, and I wasnt able to find adequate info regarding the PT. Im using a repro chassis, so Im stuck with a 2"x2.5" footprint. Ive come across several PTs with a 70mA current rating, and Im unsure if that is adequate for modern usage. The amp will be slightly modified from the stock power supply, as I will be using a 5V4 rectifier, increased filter capacitance and an added choke. Im hoping to get around 360-380V on the plates, and idle the 6V6s at around 13-15W.
    Allen Amps also has a beefed up version of this PT, with 150mA current capacity. Would there be any tonal advantage going with this one? This amp will definitley be played mildly cranked, so Ill need all components to keep up. Thoughts? Any math to go along with your thoughts would be helpful
    Supporting Member tubeswell's Avatar
    Feb 2007
    Wellington NZ
    3,774
    Blog Entries
    1
    Quote Originally Posted by EETStudent View Post
    Not sure about the 5F11, but 80mA is mentioned on 5B3 layout drawing (similar tube compliment), but I'd think 100mA is plenty for 2 x 6V6s and 2 x 12AX7s
    Senior Hollow State Tech Bruce / Mission Amps's Avatar
    Denver, Colorado
    2,892
    Quote Originally Posted by tubeswell View Post
    Yeah for a stock 5F11 or equivalent, a power transformer about the size found in a BF or SF Princeton Reverb or Vibro Champ, is good enough.
    The OT from a 2x6V6 Princeton Reverb is good too.
    Bruce
    Mission Amps
    Denver, CO. 80022
    www.missionamps.com
    303-955-2412
    Nov 2007
    Columbia, SC
    409
    Quote Originally Posted by Bruce / Mission Amps View Post
    Yea this was my thinking as well. I went ahead and went with Weber's version, which is rated at 100mA, 330-0-330. Those numbers are perfect, but there is no bias tap. Theres no reason why I cant take the bias off the HT(ala 6G2), right?
    Feb 2007
    Wellington NZ
    3,774
    Blog Entries
    1
    Yeah - just copy the 6G2 or similar (but make the supply adjustable)
  1. Vibrolux 5f11 build from integrated amp
    By tonebrulee in forum Conversion Projects
    Last Post: 07-27-2012, 06:12 PM
  2. 5F11 Vibrolux build - pics
    By Crawfish in forum Tweed Builders
    Last Post: 04-21-2008, 01:18 AM
  3. Vibrolux 5F11 - Selenium Rectifier
    By greg in forum Tweed Builders
    Last Post: 08-17-2007, 02:59 PM
  4. PT current rating Q
    By Ptron in forum Theory & Design
    Last Post: 08-14-2007, 01:53 AM
  5. PT current rating for 6L6 in Brown Princeton
    By pete_b in forum Tweed Builders
    Last Post: 06-13-2006, 09:31 PM
