Go Back   Music Electronics Forum > Instrumentation > Guitar Tech
Old 07-02-2007, 04:25 PM   #1
Cool Fender Electric XII
Good morning, campers!
I'm the (semi-proud) owner of an '66 Electric XII, as fine an oar as one could want. Not much of a guitar as it came from Fullerton, though. When I got it, it had a rollered semi-gloss white paint job over a poorly-sprayed LPB finish over a factory 'burst. It also has a B-width neck (1-5/8" at the nut,) which means it's totally unplayable as a 12-string. I'm building my own neck for it, and using ReRanch primer and LPB, Stew-Mac truss rod, fingerboard, and inlays. Slowly, slowly....
Where I need help is trying to find a schematic for wiring it up. Any suggestions, other than buying a Rick?
Thanks,
dB
diode breath is offline   Reply With Quote
Old 12-27-2009, 06:48 PM   #2
schematic
Ric posts their schematics on their site. I used it when i rewired my 12 with vintage reissue Ric toaster pups.
so - did you finish th deed? too bad it was poorly refinned whne you got it. Those old 12s are nice guitars. Page used one on Stairway to Heaven...
bosrocker51 is offline   Reply With Quote
Old 02-26-2010, 03:28 AM   #3
Thanks,
dB
I have one and I agree, it's really hard to play.
devnull is offline   Reply With Quote
Old 03-02-2010, 07:38 PM   #4
Did you try a new nut with closer spacing for the string pairs? Some of the Ric guys have reported much better playability that way.
- Scott
ThermionicScott is offline   Reply With Quote
Old 03-03-2010, 02:40 AM   #5
Quote:
- Scott
No, I haven't done that but I suspect it wouldn't hurt. I don't have the skill to make a 12 string nut (I can make pretty good 6 string ones). I wonder how much a luthier would charge to make one?
electric noise problem jerry8jb Guitar Tech 4 01-13-2008 03:02 AM
EHX Electric Mistress Repair spiritquest Guitar Effects 0 06-09-2007 12:42 PM
Deluxe Electric Mistress resistor question Neal Guitar Effects 1 04-27-2007 07:15 PM
Electric mistress regulation mod ? okgb Mods & Tweeks 1 03-02-2007 11:48 PM
Component question on Electric Mistress Neal Guitar Effects 7 06-23-2006 06:21 PM
