Results 1 to 19 of 19
Like Tree5Likes
  • 1 Post By vintagekiki
  • 4 Post By petard
Thread: Fender Mustang II amp no output, looking for schematic
    Sep 2008
    Mpls. Mn
    29
    Hi All fellow repair techs,
    I'm working on a Mustang II amp with no output, first I thought it would just changing the TDA7294 IC, which I did, still no sound.
    After looking up the IC's specs and getting some voltage info, I found the mute and standby voltages were missing.
    Using two 9v batteries I replaced the missing power to the IC, and the amp came on.
    Without a schematic this looks like a real tough repair to find the problem, does anyone have a schematic of this amp?
    Regards
    Dean C
    Dec 2008
    Wernersville, PA
    11,911
    If you do not have a schematic on hand, make one.
    Follow the mute pin back & draw it.
    Marshall uses a transistor & a zener diode/ capacitor to slower ramp up the voltage (anti turn on thump).
    Sep 2008
    Mpls. Mn
    29
    Hi jazz p Bass
    Thanks for the reply, IF it was a Marshall I could do that, the problem is its all surface mount components and has a large micro processor board mounted on top of it.
    The mute voltage is not coming from the switching power supply directly cause I've checked that out already.
    Regards,
    Dean
    Jun 2007
    4,935
    I haven't been inside one, but check the input jack it could trigger the mute as well as the headphone jack, etc.
    Lifetime Member Enzo's Avatar
    Lansing, Michigan, USA
    28,883
    So call Fender and ask for the schematic.
    Sep 2008
    Mpls. Mn
    29
    Thanks for the idea Bill,
    I checked the jacks and they are good.
    Regards
    Dean
  7. #7
    Sep 2008
    Mpls. Mn
    29
    Thanks Enzo,
    But I am not an authorized service repair center for Fender.
    Regards
    Dean
  8. #8
    28,883
    And you don't always have to be. Call them, the worst that could happen is they say "no."
    Never think up reasons not to check something.
  9. #9
    Dec 2008
    Wernersville, PA
    11,911
    I would check the resistance of the mute pin to ground.
    If it's open, then something in the mute circuit is blown.
    At that point, find a 5 volt source & hook it up to the pin.
  10. #10
    Jan 2017
    11
    Hi Dehn, I have the same problem, how can I fix it? Thanks is my first time in this forum
  11. #11
    Senior Member vintagekiki's Avatar
    Jul 2006
    930
  12. #12
    Jan 2017
    11
    thanks vintagekiki
    But I already have the schematic of the amplifier, my problem is that I have no voltage in the mute or stand by, I have no sound at the output, I see that comes from the transistor Q100 2N4403 ,
    That's why I ask if that's the problem, sorry my English im Spanish
  13. #13
    Sep 2008
    Mpls. Mn
    29
    Hi Petard,
    After begging to Fender at least four times, someone did send the schematics.
    It was a bad 15 volt regulator IC either U107 or U108 I don't remember it was a couple years ago.
    regards
    Dehn
  14. #14
    Jan 2017
    11
    Ok Dehn thank you so much,i will watch IC ,i hope that's the problem, this IC is on the motherboard?
  15. #15
    Jul 2006
    930
    Mustang main board schematics page 6
    U107/ U108 positition on schematics A (left) 5 (down)
    The Dude likes this.
  16. #16
    Jan 2017
    11
    Thanks to all and find the problem of my fender mustang, resistance R160 1W completely burned, U170 also damaged, will soon sound again ...
    Without your help it would have been impossible greetings from Spain
  17. #17
    Jul 2006
    930
    If R160 (22R/ 1W) burned check (replace) C142, C181
    Before any intervention first dismantle U108 (7915) and with an ohmmeter check for possible short circuit between -15V supply and the ground.
    If U108 (7915) burned check (replace) U108 (7915), D122, capacitors in -15V supply C145 ... C155, C183 (0.1uF) C144 (10uF / 16V)
  18. #18
    Jan 2017
    11
    Thanks for your help vintagekiki I am looking at the schematic and I see everything I have to replace ..in my city there is nothing I have to buy outside, I think the quality of this amplifier is bad they all burned
  19. #19
    Jan 2017
    11
    hello my fender mustang work!!! thank you all C181 is short and burned resistence R160
  1. Fender Mustang bass Rewind
    By big_teee in forum Beginner/ Hobbyist
    Last Post: 05-30-2014, 02:45 AM
  2. Schematic for Ashdown EVO II 500 power amp
    By cood in forum Schematic Requests
    Last Post: 05-21-2014, 09:58 AM
  3. Fender Deluxe II Footswitch Schematic
    By TomCarlos in forum Schematic Requests
    Last Post: 02-18-2014, 12:01 AM
  4. Fender Stage Lead II Amp
    By Chaffeekid in forum Vintage Amps
    Last Post: 05-07-2011, 04:19 PM
  5. Fender Mustang I and II amps
    By jessadr in forum Schematic Requests
    Last Post: 04-26-2011, 12:53 AM
