I don't know what this PI is called, but as for pros and cons I would expect it to be less balanced than a LTP. I suppose the difference in plate loads would help in that respect. It should handle a larger signal swing since there is no tail resistor to drop voltage. And you don't need a coupling cap between the volume control and the input since the grids are referenced to ground.
DG
LinkBack URL
About LinkBacks
