Results 1 to 5 of 5
Thread: What winding speed do you use.
    Nov 2014
    Was just curious what guys wind at.
    I use roughly 1200 rpm, slow, but I like the tension on the fingers at that speed....and my pace across the coil is easy to time, just used to it.
    Was just curious what other folks are doing.
    ToneOholic! big_teee's Avatar
    Jun 2010
    Mid-South USA
    I consider 1200 to be fast for hand winding with fingers.
    That means you can wind a strat coil in 6-8 minutes.
    I wind at different speeds, when winding a coil.
    Start slow, fast in the middle, and slow at the end.
    If you wind faster than that, it is harder to control all the variables.
    Technicians Run the World, but Bankers, Lawyers, and Accountants, Take All The Credit!
    Keep Rockin! B_T
    Nov 2014
    I find when I get to 1500 things can get squirly.
    I don't use stops or a guide, just free hand it on to the bobbin.
    Once I get the bobbin loaded on the winder, yeah, might take 5 minutes to wind a bucker coil, with stops and starts to check how it's laying down.
    CNC Trial by Fire kayakerca's Avatar
    Jul 2011
    Ottawa, CANADA
    1,131 rpm for my product.
    796 rpm for vintage Fender rewinds.
    I stop every ~ 2,000 turns or so to make sure the wire is laying down the way I want it to lay down.
    Take Care,
    Jim. . .
    In the immortal words of Dr. Johnny Fever, “When everyone is out to get you, paranoid is just good thinking.”
    An idea to see how the wire is laying down is to use a strobolight.
    See it (2.40mn)at :
  1. Speed Control for Variable Speed Motor/Winder
    By jrdamien in forum Tools and Coil Winding Gear
    Last Post: 08-14-2015, 08:06 PM
  2. Speed Control for Variable Speed Motor/Winder
    By jrdamien in forum Pickup Makers
    Last Post: 07-27-2015, 09:00 PM
  3. Replies: 20
    Last Post: 07-27-2011, 01:40 PM
  4. Replies: 15
    Last Post: 12-17-2008, 04:12 AM
  5. Does winding speed make a difference?
    By madialex in forum Pickup Makers
    Last Post: 10-17-2007, 01:56 PM
