Results 1 to 4 of 4
Like Tree1Likes
  • 1 Post By 52 Bill
Thread: Replacement Transformer For Fender Deluxe Reverb Reissue - wiring question
    Sep 2007
    Massachusetts
    267
    I have some questions about the wiring colors/assignments when using the Mercury Magnetics APS FDR-PRI Transformer as a replacement in a Fender Deluxe Reverb 65 Reissue (DRRI). I am hoping somebody might take a minute or two to help.
    65_Deluxe_Reverb_RI.pdf
    Merc Mag DRRI TX.PDF
    Please refer to the Fender DRRI and the Mercury Magnetics schematics attached. The Fender schematic I will reference is on page 6 of the attached Deluxe Reverb RI Owner's Manual.
    The solid red, solid yellow and solid green wires are self explanatory and pose no questions as to their use when comparing the schematics.
    On the Mercury Magnetics replacement transformer - does the "red/yellow" wire correspond exactly to the "red/yellow" on the Fender schematic? Does the Mercury wire marked "red/wht" correspond to the "red/blue" on the schematic?
    Finally, on the Mercury transformer, do I cut back and insulate the "grn/yel" wire?
    Thanks in advance for your help!
    Earache
    Jun 2007
    4,977
    Quote Originally Posted by earache View Post
    Yes, the red/yellow are the same and the red/white is equivalent to the red/blue of the original for the bias supply.
    And the center tap for the 6 volt filaments is not needed, so insulate the green/yellow wire.
    Mick Bailey likes this.
    Sep 2007
    Massachusetts
    267
    52 Bill
    Thanks for your reply. You guys are always so very helpful!
    Earache
    Sep 2007
    Massachusetts
    267
    All
    I want to also give props to the tech support at Mercury Magnetics, in particular Patrick Selfridge, who replied to this same question within a few hours of my sending it.
    Good tech support is hard to find sometimes, but not at Mercury Magnetics!
  1. Fender Deluxe Reverb Reissue (2002)
    By PLF in forum Guitar Amps
    Last Post: 01-05-2016, 05:26 PM
  2. Fender Twin Reverb 65 Reissue 6L6 Tube Replacement
    By TomCarlos in forum Tubes (Valves)
    Last Post: 02-15-2015, 04:04 AM
  3. Fender 65 Deluxe Reverb Reissue Power Transformer?
    By Tonestack in forum Guitar Amps
    Last Post: 07-10-2010, 01:43 PM
  4. QUESTION: Biasing a '65 Reissue Deluxe Reverb
    By Mango Moon in forum Maintenance, Troubleshooting & Repair
    Last Post: 10-09-2008, 02:30 AM
  5. Deluxe Reverb Reissue project, wiring
    By johnwilliamhunter in forum Build Your Amp
    Last Post: 06-17-2008, 02:38 AM
