Results 1 to 7 of 7
Thread: New amp build transformer suggestions
    May 2017
    3
    Dear colleagues,
    I am looking to build a Bad Cat Hot Cat amp. The schematic is included. Instead of making a dual EL34 version I want to downsize this to a single EL34 tube. I am looking for how to calculate the PT and OT and choke for this configuration. I have what I think are the original specs for the full version. Any help would be appreciated.
    *575 volt ac ct 600 ma************285-0-285 250MA
    * * *6.3 volt 6 amps***************5.0 Volt 3 Amps
    * * *5.0 volt 5 amps***************6.3 Volt 6 Amps
    30 watt Choke: T541690
    * * * Inductance 36 Henries
    30 Watt Output: T541691 Cutout 1 x 2
    * * *Primary Impedance 4000 ohms
    * * *Secondary Impedance 4,18,16 ohms
    Thanks in advance,
    Daniel
    Attached Files Attached Files
    Aug 2012
    Great Black Swamp
    1,653
    Welcome to the forum, Daniel!
    Quote Originally Posted by Bonsaimaster View Post
    Not sure what this means. How many filament windings are there on the PT? Also, the schem linked does not come up. There was a server crash a few years ago that corrupted the links.
    But in general answer to your question, turning a push-pull amp into a single-ended amp will require some design changes to the power amp section - mostly the phase splitter circuit - and a downgrade to the power supply. Then the gain throughout the amp will need to be checked and massaged to see how it compares to the original design. Why not find a SE EL34 circuit out there to build, try it and then see what could make it more like the bad cat. I'm not familiar with the bad cat, but I'll hazard a guess and say the preamp is similar to many Fender and early Marshall designs.
    If it still won't get loud enough, it's probably broken.
    We need more chaos in music, in art... I'm here to make it.
    May 2013
    111
    This is the schematic: http://schems.com/bmampscom/badcat/badcat_hotcat_30.pdf
    I'd go from V1b to V3b with another 470k la Marshall 1959.
    Then from F to the Power tube.
    As for the PT, please specify what do you have actually, as per the information shown on my link, voltages are different.
    Thanks.
    May 2017
    3
    Quote Originally Posted by Roberto View Post
    Thanks.
    Ok I feel like an idiot. I Thought this was a SE design but realize it is a cathode bias PP amp. Ok I am using this transformer (320-0-320) at 150mA center tapped, 6.3V (3.15-0-3.15) at 4A center tapped and 5V at 2A.
    Ok I think best to keep the PP design. So the question is which output transformer to use? I have two Classic Tone transformers
    40-18049
    40-18006
    40-18080 Hi Fi version
    The first two have the same specs but different in size. So there must be something else going on.
    Also do I need a 36H choke? I would like to use a 30H one.
    Thanks
    Bonsaimaster
    May 2013
    111
    Hi Bonsaimaster,
    Do tou have the direct links or specs of the cited OTs?
    Just to tell you which one fits better the actual configuration.
    You'd like to use one single SE to reduce the power?
    you could choose a EL84 PP instead.
    Around 8k Raa.
    May 2017
    3
    Hi Bonsaimaster,
    Around 8k Raa.
    I think I will stay with the EL34 PP
    40-18080
    Vox AC 30 Vintage Style Output Transformer, 4/8/16 Ohm
    Fender Output Transformer, Bandmaster, Pro, Vibrolux, Tremolux, Vibroverb, 4/8/16 Ohm
    Thanks!
  7. #7
    May 2013
    111
    If you want to do some trials on the sound and not an exact replica, you can chose the first OT: it has 4.4 and 6.6k taps plus the UL ones. Many switchable options.
    Otherwise the other two seems quite similar (but I don't have direct experience on them).
  1. starting amp build advice/suggestions
    By Richard in forum Theory & Design
    Last Post: 07-19-2014, 05:21 PM
  2. Replies: 2
    Last Post: 01-19-2014, 08:24 PM
  3. Starting first amp build. Suggestions on components please?!
    By hesamadman in forum Build Your Amp
    Last Post: 06-25-2013, 09:17 PM
  4. Fender 6G6 Build w GZ34 - Transformer Suggestions?
    By Jecarroll7 in forum Maintenance, Troubleshooting & Repair
    Last Post: 05-14-2013, 10:58 PM
  5. Suggestions for 2nd tube amp build
    By menlow in forum Guitar Amps
    Last Post: 01-06-2012, 07:07 AM
