Results 1 to 6 of 6
Like Tree7Likes
  • 1 Post By Enzo
  • 2 Post By rjb
  • 4 Post By Mick Bailey
Thread: Ground loops in a guitar ?
    Woodgrinder/Pickupwinder copperheadroads's Avatar
    Jun 2009
    Iceburg Alley ,Newfoundland,CAN
    2,025
    I know it exist in Amp building but in a guitar ? I'm not convinced & i keep hearing this from newbies .........or players with more basic understanding .
    go ahead let me know what you think ...................
    "UP here in the Canada we shoot things we don't understand"
    Lifetime Member Enzo's Avatar
    Lansing, Michigan, USA
    29,180
    I would think only when people mis-use the term ground loop. Many people call anything making hum a "ground loop". To me, a ground loop occurs when two pieces of equipment have differing ground potentials are connected together by an additional ground path, like a cord between two amps. I am not sure how you could have multiple current paths in the ground inside my guitar.
    But I freely admit I am not a guitar guy, I am an amp guy.
    The Dude likes this.
    May 2007
    pacific north west
    12,515
    +1
    The differential voltages and relatively short ground leads in a guitar (even relative to their low output and that they will be extremely amplified) seem too low to be problematic. I've never had a particular guitar that seemed to hum more than usual unless it was a gain issue more related to hot pickups. I do know I've read about it happening though. Since I don't have those suspect guitars on my bench I can't verify one way or the other. But I lean toward "Not a problem".
    "So I acquired it for the purpose of fixing it up - in case I run out of things to do with the rest of my life..." tubeswell
    "Shut up, you big dumb poopy-head!" Justin Thomas
    rjb
    rjb is offline
    Feb 2010
    Somewhere near Bawlmer, Merlin
    2,199
    If you run the ground wires in a path that forms a closed loop, I suppose you technically have a loop antenna - which is not the same thing as a ground loop as Enzo elucidated. But I doubt it will make any difference.
    Just don't ground your guitar like this:
    Chuck H and copperheadroads like this.
    Mar 2008
    417
    The ground loops by itself is not a big deal (I saw a lot of working circuits with mistakes) the problem is difference of potential between path in a loop which determine a current to run modulating the signal. Good practice should avoid it.
    Supporting Member
    Dec 2009
    UK
    3,025
    I work on guitar electronics pretty much every day, day-in, day-out. I've never seen a guitar that's had a 'ground loop' (in the conventional sense of the term). If this were possible, then guitars would need to be bus connected, or star-grounded. Sure, there are numerous ground issues that can occur, but the potentials, current flow and resistances involved make the scenario theoretical and based on micro-potentials which would make no audible difference.
    I say that fully with the knowledge that I have a customer who swears he can hear the difference between pickup selections on a Les Paul when the guitar is played acoustically and not plugged in. So, I guess 'hearing' ground loops for some is eminently possible, as are voices from the spirit world.
    Chuck H, rjb, The Dude and 1 others like this.
  1. Ground Loops in AB763 Deluxe
    By mikepukmel in forum Build Your Amp
    Last Post: 03-24-2017, 10:07 PM
  2. Pedalboard Ground Loops
    By mhuss in forum Guitar Effects
    Last Post: 06-22-2015, 05:10 PM
  3. Ground Loops In PC Board Interconnects
    By TomCarlos in forum Guitar Amps
    Last Post: 02-23-2014, 06:14 AM
  4. Hums, ground loops, and strange squeals.
    By theWicked in forum Maintenance, Troubleshooting & Repair
    Last Post: 11-04-2010, 02:59 AM
  5. Lifting Ground Loops in a 6G15 Stand Alone Reverb
    By tubeswell in forum Tweed Builders
    Last Post: 12-03-2008, 02:06 AM
