Results 1 to 13 of 13
Like Tree6Likes
  • 1 Post By Justin Thomas
  • 1 Post By Enzo
  • 1 Post By The Dude
  • 1 Post By bob p
  • 2 Post By KRKozBassman
Thread: JJ 6550 max volts only 600?
    Mar 2017
    10
    If an SVT plate voltage is 660 volts why is it OK to put in a JJ 6550 if the Max voltage on a JJ is only 600 volts?
    http://www.jj-electronic.com/images/...s/pdf/6550.pdf
    Chill-Ville, VA
    2,307
    For the same reasons it's okay to put a 6V6GTA in a Deluxe Reverb @ 420V. Voltage isn't what kills tubes, HEAT does. There's a lot more wiggle room in plate voltages being too high if you bias within reason - which basically means, if you're not dead-set on running your tubes as hot as possible, usually following the "interweb-lore rule" of 70% max plate dissipation. Personally, I think 70% should be an upper extreme, not an "ideal" setting.
    I think running the screens safely and according to spec is a lot more important than plates. Usually when tubes die, it's a grid failure of some sort - often the screen grid softens, sags, and shorts to something else inside the tube.
    Justin
    DRH1958 likes this.
    "If you're using one of those Digiyuk module type things..." - Chuck H. -
    Lifetime Member Enzo's Avatar
    Lansing, Michigan, USA
    29,152
    Plus 660v is only 10% higher than 600v. Tubes certainly are not worried about 10% variations.
    Justin Thomas likes this.
    Mar 2017
    10
    Thank you! According to the schematic i'm setting the bias at the stated 24mV (across 10ohm resistor) which works out to be only 46%. 35w/660v*0.46 = ~24. Is this correct? Is this theoretically going to make the tubes last longer?
    g1
    g1 is offline
    Feb 2010
    9,334
    It is a 1 ohm resistor, not 10 ohm.
    The factory setting is .072V at the test point, which is for 3 power tubes, so it works out to .024Amps per tube.
    That factory setting was for 42W 6550's so it was about 38%.
    If you use 35W modern 6550's, the .072 setting at the test point will work out to 46% like you figured.
    Certified Dotard
    Mar 2017
    10
    Quote Originally Posted by g1 View Post
    Sorry but it's 10 ohms per tube - mine is an SVT-2 pro and an SVT-CL have the same set up with the LED/OP amp circuit. It doesn't have user test points on the back, you have to take the bottom off and check across 6 resistors.
  7. #7
    Supporting Member The Dude's Avatar
    May 2010
    Sioux Falls, SD
    4,702
    I guess I'm not understanding what the goal is here. Why not just use the LED bias procedure recommended for the amp? Also 24mV across 10 ohms would be only 2.4mA. I would think that would put you into crossover distortion territory (assuming we're talking about cathode resistors?).
    g1 likes this.
    “Yeah, well, you know, that’s just, like, your opinion, man.”
  8. #8
    Mar 2017
    10
    Quote Originally Posted by The Dude View Post
    Sorry about that - it's 0.24 volts across a 10 ohm resistor - duh!
    My goal is really to optimize to the best performance possible I am a engineer that works on automated machines ( I started working on tube and solid-state amps back in my early 20s - I'm 48 now) and over the years the manufacturer has not always been right so I guess I'm just being picky...
  9. #9
    Cornelius, Oregon
    1,271
    The original SVT was biased pretty cold, and while the plate might have been at 660V, the screen was much lower....maybe around 350V, I forget without looking at a schematic. Anyway, having the screen a lot lower like that is a good way to get a lot of power and have the tubes last a long time too. I used some Svetlana (Winged C) 6550C's in the vintage SVT that I had, set at the factory recommended bias, and they were still going strong in that amp 10 years after I put the tubes in. The amp saw weekly gigging use for the whole time, and all tubes were still working perfectly when I sold the amp a couple years ago.
    Greg
  10. #10
    g1
    g1 is offline
    Feb 2010
    9,334
    Ok, SVT-2PRO. You mentioned SVT so I assumed you meant the vintage one. And the 24mA you mentioned worked out nicely to 1/3 of the vintage ".072V" spec. so I figured that was where you got the number from.
    As you mentioned, the schematic shows .24V across 10 ohms. I would assume this is the correct level to make the light green, you can verify.
    As far as tube life, with it biased at the stock spec., you should get the tube life they found to be the longest possible without having a negative impact on the performance.
    Once again, it depends if they designed the amp with the 42W version or 35W version of 6550.
    If stock was the 42W tube, using a 35W tube at the stock idle current will be 'relatively' hotter (% of max.W). Again, if it was designed with the 42W tubes, I would not expect the 35W version of 6550's to last as long as the 42W, and perhaps will not deliver the full power the amp is rated for.
    Certified Dotard
  11. #11
    Better Tone thru Mathematics bob p's Avatar
    Chicago, USA
    4,228
    Quote Originally Posted by KRKozBassman View Post
    I don't understand why you're pulling the chassis, flipping it over and checking voltage on the current sense resistors, when that amp is designed with a bias monitoring circuit so that you don't have to bother doing that. The official bias procedure for the SVT-2PRO is to adjust bias using the idiot lights on the rear panel, which are engineered to provide the right information. Comparators in the protection circuit will take care of the rest.
    419xxh2-pa-driver.pdf
    The Dude likes this.
  12. #12
    Mar 2017
    10
    The schematic says 6550A and the data sheet for 1972 GE 6550A is 42 watts so I going with that and the Tung Sol 6550 reissue I have in the amp also states 42 watts. So that would make it only 38% (42w/660v*0.38 = ~24). I think my OCD is satisfied.
    g1 and The Dude like this.
  13. #13
    Mar 2017
    10
    Quote Originally Posted by bob p View Post
Name:	419xxh2  PA driver.pdf
    The LED's have a range they work in when green only is on that is approximately 15mA (24%) to 30mA (29%) and I just like to be precise. I know it doesn't really matter, it's just me.
  1. 33,000 Volts
    By JHow in forum Lobby
    Last Post: 05-06-2012, 06:28 PM
  2. Marshall JTM 30 conversion to 110 volts from 230 volts
    By misterc57 in forum Maintenance, Troubleshooting & Repair
    Last Post: 04-26-2010, 02:40 AM
  3. 315 volts on a 12ax7?
    By camnicklaus in forum Maintenance, Troubleshooting & Repair
    Last Post: 12-23-2008, 05:44 PM
  4. Watts-volts chart
    By Enzo in forum Theory & Design
    Last Post: 09-07-2008, 10:55 PM
  5. 100 volts???
    By Boy Howdy in forum Guitar Effects
    Last Post: 12-11-2007, 03:53 AM
