Results 1 to 10 of 10
Thread: Relay supply
    Jun 2007
    Pensacola, FL
    3,514
    Thumbs Up/Down
    Received: 0/0
    Given: 2/0
    Relay supply
    Just need someone to check my homework on this supply. The 21vDC is tapped from a 6800uf cap.
    The relay is:
    http://www.mouser.com/Search/m_Produ...DA6e0NZw%3D%3D
    Datasheet states about 20ma of coil current.
    Do the resistor, zener, cap all fit value-wise? I found with my basic calculations that they will work but would like another set of eyes on it.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
    0 Not allowed! Not allowed!
    Lifetime Member Enzo's Avatar
    Lansing, Michigan, USA
    30,175
    Thumbs Up/Down
    Received: 269/1
    Given: 0/0
    Try it a different way.
    The relay is a 12v coil? And it wants 20ma current? use Ohm's Law. 21vDC supply, less 12v leaves 9v to drop across a resistor. 20ma dropping 9v across a resistor? R = V/I = 9/0.02 = 450 ohms. 470 is the nearest standard value. SO just put a 470 ohm resistor in series with your coil and run it on 21v. None of the other stuff needed.
    However you power it, put a reverse diode across the coil.
    Jun 2007
    Pensacola, FL
    3,514
    Thumbs Up/Down
    Received: 0/0
    Given: 2/0
    Thanks Enzo. Hey that's great I can save on space, pcb, and extra parts. I guess relays are fairly forgiving with coil voltage tolerance. Awesome.
    Jun 2007
    Pensacola, FL
    3,514
    Thumbs Up/Down
    Received: 0/0
    Given: 2/0
    Shall I pick a diode that can withstand about twice 2x 12v forward and same for reverse breakdown?
    30,175
    Thumbs Up/Down
    Received: 269/1
    Given: 0/0
    A plain old 1N4148 is usually what they use, but if you don't have one, a 1N4007 is fine too.
    As to 12v, I doubt you can find many diodes with less that 24v ratings either way.
    Look at the relay circuits in a 5150 for example.
    Old Timer J M Fahey's Avatar
    Oct 2007
    Buenos Aires, Argentina
    10,201
    Thumbs Up/Down
    Received: 245/3
    Given: 253/4
    As a side note:
    Not really, but relay coil will never see 21V at all.
    With switch open: zero current so voltage drop across coil ends.
    With switch closed: resistor drops 9V, relay drops remaining 12V ; resistor is always in series.
    Diode across coil also sees 12V reverse voltage and passes 20mA for a millisecond after switch opens.
  7. #7
    Jun 2007
    Pensacola, FL
    3,514
    Thumbs Up/Down
    Received: 0/0
    Given: 2/0
    So I'm considering the 24v relay
    http://www.mouser.com/Search/m_Produ...OC8r3WaA%3d%3d
    From the datasheet it says the relay will work fine and still have some room for voltage tolerance if I just run it off 21vDC. Reason being one less component...the current limiting voltage divider resistor.
    The datasheet says 70% or more of specified voltage and not more than 10% OVER. 70% of 21vDC is about 16v. I highly doubt any mains voltage will drop that far.
    Any errors in my thinking here? I like the simplicity. A relay and a flyback diode. Nothing else.
    Is there any reason to have the relay decoupled from the main 21v rails? (They are the supply for a LM3886)
  8. #8
    Oct 2007
    10,201
    Thumbs Up/Down
    Received: 245/3
    Given: 253/4
    Oh, it will work fine with 21V.
    But are those 21V always availble? If that´s a raw supply rail for the LM3886, it might easily drop up to 20% under full power, 10% for certain.
    If that´s still enough, go ahead.
  9. #9
    Supporting Member The Dude's Avatar
    May 2010
    Sioux Falls, SD
    5,165
    Thumbs Up/Down
    Received: 131/0
    Given: 111/0
    Without some isolation, there's also a higher chance for relay switching noise appearing at the output.
    “Yeah, well, you know, that’s just, like, your opinion, man.”
  10. #10
    Jun 2007
    Pensacola, FL
    3,514
    Thumbs Up/Down
    Received: 0/0
    Given: 2/0
    Thanks guys. Both great reasons to go 470ohm (or a bit less for supply sag) and 12v relay.
  1. Mojotone 5v Relay Supply
    By lowell in forum Theory & Design
    Last Post: 05-08-2015, 08:21 PM
  2. elevated filaments and relay supply
    By CopperWings in forum Theory & Design
    Last Post: 03-21-2012, 05:31 PM
  3. Relay supply fuse
    Last Post: 03-11-2011, 01:18 AM
  4. bias tap - relay supply
    Last Post: 10-29-2010, 07:51 PM
  5. Relay power supply
    By Synaptic Amps in forum Theory & Design
    Last Post: 07-08-2008, 10:03 AM
