Page 1 of 2 12 LastLast
Results 1 to 35 of 43
Thread: Fishman Loudbox PRO-LBX-300
    Oct 2011
    48
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    Hello all. I have a Fishman Loudbox PRO-LBX-300 amplifier that is not working. It was left on by accident for a few days and upon discovery the fuse was blown. I replaced the 2a slow blow fuse and powered it on. It made a loud buzz and then immediately blew the fuse. I checked the googlewebs for a schematic and it brought me here:
    http://music-electronics-forum.com/t40099/
    It doesn't seem that the schematics are right for my application. On the main board mounted to the heatsink it is labeled: Loudbox Café PowerAmp, rev. 3.0, 459-000-024. One of the other boards is labeled: Fishman Transducers, rev 2.0, 459-000-032.
    I can use a multi meter and can solder fairly well.
    Where do I start? Thank you in advance for your time.
    0 Not allowed! Not allowed!
    Oct 2011
    48
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    I should also add that one of the boards has a 2005 date.
    Supporting Member
    Dec 2009
    UK
    3,253
    Thumbs Up/Down
    Received: 19/0
    Given: 2/0
    My guess is you have a shorted output device and the loud buzz is the high ripple on the PSU caused by excessive loading. Disconnect the speaker & tweeter, power up the amp with a new fuse and measure across the outputs for the tweeter and main power amps. If you have more than a few mV DC then this points to a short.
    If you have a variac then you can bring up the amp slowly and monitor the output for DC. If you don't already have one then a bulb limiter is a useful protection device while you're troubleshooting.
    Oct 2011
    48
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    Thank you for the reply. Upon closer inspection, the yellow wire off the HP plug is disconnected. It appears the lug somehow broke off. I tried to attach a jumper to see if this was the problem and my breaker popped. When I reset the breaker and left the yellow wire unattached the noise was there. I ran it through a variac and at 10 volts it was making noise. I then took out the speakers and disconnected them all and put my meter on the wires for the tweeter. No voltage. I looked closer at the Power Supply board that is connected to the heatsink and there appears to be a small cap broken off with the trace from the board attached. I'll try and successfully post some photos. Thoughts?
    Oct 2011
    48
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    Oct 2011
    48
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    Anytime the yellow wire is attached it either pops my breaker, or blows the 2a slo blow fuse.
  7. #7
    Supporting Member
    Dec 2009
    UK
    3,253
    Thumbs Up/Down
    Received: 19/0
    Given: 2/0
    Are you referring to the yellow wire coming off the mains socket? If so, I can't quite see where the wiring runs but you appear to have black,white,green/yellow leads already connected and it looks to me like that yellow lead does not belong there. None of the pictures of the socket that turn up show an additional terminal. The capacitor is another matter - it's probably shorted and needs replacing.
  8. #8
    Oct 2011
    48
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    This is the yellow I am talking about. Click image for larger version.
  9. #9
    Oct 2011
    48
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    Here's the other end. It had a lug in it, so I assume It had to be connected to something...
  10. #10
    Oct 2011
    48
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    There's no obvious place to my eye that the yellow would be, I've looked over the boards and this doesn't appear to have gone to the transformer, it was laying right near the main power socket, I assumed it went here, but I suppose it could have been just extra material cut off.
  11. #11
    Oct 2011
    48
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    I also discovered another capacitor broken or blown off... Here's a few better photos.
  12. #12
    Oct 2011
    48
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    And another:
    Sorry for the multiple messages, I don't know how to attach photos more than one at a time.
  13. #13
    Lifetime Member Enzo's Avatar
    Lansing, Michigan, USA
    30,433
    Thumbs Up/Down
    Received: 446/1
    Given: 0/0
    Where does the blue wire next to it go, perhaps to the tweeter? And if so is there a second wire on the tweeter? It looks like the male pin for the female on the yellow wire broke off of something, perhaps off the tweeter?
    To assist my theory, do the red and black wires go to the woofer? I mean the red and black right with the blue and yellow, not the lone red and black to the left.
    This is just a thought, it might be something else of course.
  14. #14
    Dec 2008
    Wernersville, PA
    12,279
    Thumbs Up/Down
    Received: 63/0
    Given: 21/0
    Quote Originally Posted by gibson17 View Post
    Is there a 'fuse holder' in thar IEC socket.
    If so, then that is the fuse out power wire. (broken off)
  15. #15
    Supporting Member
    Dec 2009
    UK
    3,253
    Thumbs Up/Down
    Received: 19/0
    Given: 2/0
    None of the pictures I can find of that socket show a terminal coming off in that position. If this were the case it would be connected directly to the unfused live connection. It also looks too small for a mains connector.
  16. #16
    Oct 2011
    48
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    After looking closer at the small tweeter, the lug is definitely broken off of there. The red and black in question goto the woofer. Is it possible that I just had the bad luck of the lug breaking off of the tweeter and falling down near the mains and it made some intermittent contact?
    What about the caps that a broken off the trace? Should I replace them, or just try to reconnect them?
  17. #17
    Oct 2011
    48
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    Quote Originally Posted by Jazz P Bass View Post
    There is a fuse holder in the socket. A 2a 250v slow blow.
  18. #18
    30,433
    Thumbs Up/Down
    Received: 446/1
    Given: 0/0
    Then the yellow wire is the output of the tweeter amp, and if you connected it to the mains fuse holder, you probably blew the tweeter amp.
  19. #19
    Oct 2011
    48
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    How do I test to see if that's the case? ... and if so, what needs to be replaced to repair it?
  20. #20
    Oct 2011
    48
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    Could contact of the output with the mains caused the caps to pop off like that?
  21. #21
    Supporting Member
    Dec 2009
    UK
    3,253
    Thumbs Up/Down
    Received: 19/0
    Given: 2/0
    Maybe, but who knows. All you know is that if the connector didn't accidentally touch the mains you made sure that it did and you could have more damage than you began with. Disconnect the speaker and tweeter outputs and see if there's DC on either output. Which part of the circuit are the damaged caps located?
  22. #22
    Oct 2011
    48
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    Quote Originally Posted by Mick Bailey View Post
    True. Speakers are disconnected. The connector that has red/black/blue/yellow goes to the small tweeter and the small mid. The connector that is away from the 4 wire connector that is a two wire connector that is Red/Black goes to the woofer.
    On the 4 wire connector, there was DC voltage present on Blue/Yellow even at very low voltage, but much less on Red/black and not so much at low voltage.
    On the 2 wire connector for the woofer there was DC voltage present even at low voltage. The unit was also drawing quite a few amps even at low voltage. 4amps before the 2a slow blow gave way.
    The damaged caps seems to be right near the r58 resistor and right below the vr2 trim pot.
  23. #23
    Supporting Member
    Dec 2009
    UK
    3,253
    Thumbs Up/Down
    Received: 19/0
    Given: 2/0
    You have three power amps that need to be checked. Plus your mains voltage could have appeared on the main PSU rails momentarily (by way of an output to supply short in U5) prior to the fuse blowing. You'll need to establish that all the DC voltages are correct and that you're not missing one of the supply rails and eliminate the possibility of excessive current draw in the PSU. The only way to do this is either to isolate the power supply or remove the excessive load so that the amp can power up. The tweeter amp chip is almost certainly blown and I'd carefully remove it to eliminate it. Sometimes the supply pins read low resistance to the output pin and give a clearer indication of failure. Worthwhile just to take a measurement. The output devices on the other two amps need checking for shorts. You should also carefully inspect the board for any other visible damage. Before embarking on any repair I would establish what's shorted/damaged. Could be you have multiple faults. Sometimes it's necessary to remove the output transistors just to get to the point where an amp can be powered without blowing the fuse and then work from there.
    What's your mains voltage?
  24. #24
    Oct 2011
    48
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    Hello there. I've been quite busy so haven't gotten a chance to reply until now. I removed the Power Amp board from the amplifier to get a clearer look at what's going on. The caps on the backside look to be the only things that have sustained any visible damage. While the power amp board was removed, I powered up the amp so I could take some measurements off of the power connector board, which is what I assume you were asking for. When I took measurements from pins 1 and 2, the meter jumped to 5 acv then dropped to zero. Measurements from 4 to 3 provided no voltage, and pins 1 to 4 produced 120v. Pins 3 and 2 also produced 120v. Without the power amp board connected no fuses blew.
    I have not gotten around to removing U5 yet. Should I reconnect the caps on the back since there are two that need attention or should I wait to get walked through it?
  25. #25
    Supporting Member
    Dec 2009
    UK
    3,253
    Thumbs Up/Down
    Received: 19/0
    Given: 2/0
    I think you're measuring the input voltage and assume you're on 120v mains.
    I'm referring to checking the DC output voltages. Take a look at the PSU and you should have +/- 33v and +/- 14v. Also check for AC - those supplies should be pretty ripple-free with no load. These voltages have to be correct before moving on. Don't reconnect the old caps - they need replacing.
  26. #26
    Oct 2011
    48
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    Hello there, been pretty busy so haven't gotten a chance to get to doing more work to this until the last few days. I removed U5, but was still blowing fuses. There amp was still drawing over 2a at about 40v. I did the smell test and Q18 was stinky and very hot. So I removed it. The amp will now idle at full power at .18 amp draw. I tried testing various points now that the amp would stay running. I took a look at the schematic and it looked like to test for those values that I should test U10, U11, BR1 areas to get the values you are looking for. I tested for both AC and DC. I did not get the numbers exactly, I came in at 35.8vdc and 14.5vdc. The outside legs of BR1 had VDC while the inside legs had VAC. Am I testing the correct points? Please advise.
  27. #27
    Oct 2011
    48
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    Hello all. I sent the board into fishman for repairs. I received it, and installed it into the amp. Upon power up, the amp is buzzing and there are no lights coming on for power or mute and the controls do nothing. When I push the phantom power in, the buzzing is about half of what it is without it the button depressed. Transformer issue? Please advise.
  28. #28
    Supporting Member The Dude's Avatar
    May 2010
    Sioux Falls, SD
    5,212
    Thumbs Up/Down
    Received: 193/0
    Given: 159/0
    I doubt a transformer failure. Measure the "buzz" at the speaker jack. Is it AC or DC and what is the level.
    “Yeah, well, you know, that’s just, like, your opinion, man.”
  29. #29
    Oct 2011
    48
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    Hello Dude, It looks like with the phantom off it's 64.6mv AC, and with phantom on, it's 39.3mv AC. I also measured on DC and got .7mv with both phantom on and off. Also was starting to get an overheating electronics smell, which I suppose could be from the board getting serviced. Also, still no lights on the control panel, which is odd.
  30. #30
    May 2010
    Sioux Falls, SD
    5,212
    Thumbs Up/Down
    Received: 193/0
    Given: 159/0
    Ok. Nothing ridiculous like full rail voltage. Double check that you hooked everything up correctly when you installed the new board. Make sure there are no bent pins in any connector. If you don't find any problems there, You'll need to troubleshoot the amp just as you normally would- new board or not. First check power supplies, etc.
    One thing to note and not talking specifically about Fishman: I have in the past gotten replacement modules that were missing parts. Are all the fuses, filter caps, etc. installed? I think my first step would be to visually scrutinize everything and make sure nothing was forgotten and that everything is hooked up correctly. Also, do you have it assembled? Sometimes grounds are carried by jacks, screws, etc. and partial assembly just won't do. The problem could be as simple as something isn't grounded.
  31. #31
    Oct 2011
    48
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    They had no replacement boards available, so I sent in the board, and they repaired it. I gave it a quick look over upon arrival, and then installed it. I assembled the entire amp, minus the grille. When I noticed there was what appeared to be no power, I took the control panel off the top of the amp and gave that a quick look over, and didn't really notice anything out the ordinary. I'll disassemble the amp again and give the board a better look. I don't really think there's any way to hook up the wires incorrectly as they only go to their own spots. There's almost no way to put the wrong connector in the wrong place. Anyway, I'll look it over and report back...
    What do you make of no lights and no control on the control panel?
    Thank you for your help.
  32. #32
    May 2010
    Sioux Falls, SD
    5,212
    Thumbs Up/Down
    Received: 193/0
    Given: 159/0
    Without knowing which schematic fits your amp (there are a few for this model), I'm just guessing. My thought would be that you are missing a low voltage supply. Maybe +5 or 15? Can you post a schematic for YOUR amp?
  33. #33
    Oct 2011
    48
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    Here's what fishman sent me.
    Attached Files Attached Files
  34. #34
    May 2010
    Sioux Falls, SD
    5,212
    Thumbs Up/Down
    Received: 193/0
    Given: 159/0
    That schematic doesn't show the preamp, which would presumably show where LED power comes from. It does show us that there is only one secondary winding with a CT. Check your supplies. There are +&-33V and +&-15V. Also, make sure the tabs on your regulators are not shorted to ground and that the insulator between them is not compromised.
    Edit: I just found a preamp schematic, but not sure it's the right one. On the one I have, the power LED is supplied by the -15V supply, so check that supply for sure if you don't have a power LED.
  35. #35
    Oct 2011
    48
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    Thank you. I have some work ahead of me. I will report back with my findings.
  1. Fishman PRO-LBX-300
    By Tech. Tom in forum Schematic Requests
    Last Post: 01-31-2018, 02:23 PM
  2. Fishman Loudbox Mini
    By corliss1 in forum Schematic Requests
    Last Post: 10-12-2016, 01:05 AM
  3. Fishman Loudbox PRO-LBX-500 schem needed please
    By jmaf in forum Schematic Requests
    Last Post: 05-11-2016, 09:20 PM
  4. Fishman Loudbox Pro - intermittent output
    By amgard in forum Maintenance, Troubleshooting & Repair
    Last Post: 12-11-2012, 01:47 AM
  5. How do I open a Fishman Loudbox?
    By Albert Kreuzer in forum Maintenance, Troubleshooting & Repair
    Last Post: 02-18-2011, 11:41 AM
