Results 1 to 5 of 5
Thread: VOX AC30C2 volume drop
    New Member
    Dec 2017
    1
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    Hi, ever since I bought my AC30C2 I've had a variety of issues regarding noises, tubes and furthermore. Now I'm having a volume drop, like the amp is running half its power, after playing for about ten minutes. It also makes a crackling noise when the volume starts dropping. I swapped all the tubes already, but who knows, maybe one is defective? In that case, which one? Or could it be a component besides tubes?
    Thank you for your help.
    0 Not allowed! Not allowed!
    Bent Member Chuck H's Avatar
    May 2007
    pacific north west
    13,321
    Thumbs Up/Down
    Received: 296/0
    Given: 383/0
    You would need to trace the AC signal voltage through the circuit. If all the panel controls are working correctly the problem is likely after the preamp, so that would narrow the search. The crackling could be indicative of a bad solder connection, a bad pot, a bad tube, a dirty tube pin or socket, etc. Unless you have a signal generator and a scope (or at least a DMM) you would probably be money ahead to take it to a pro unless you WANT to learn this stuff. Which can be fun and rewarding on it's own. But if you just want a working amp a shop may be your best bet unless you have electronic bench gear and some chops because the symptoms at this time are vague without bench tests.
    "A pedal, any kind, will not make a Guitar player more dangerous than he already is." J M Fahey
    "A shot gun delivers a force that exceeds the operational range of most systems, such as pumpkins." Antigua
    Supporting Member Randall's Avatar
    Jan 2013
    Cape Coral, FL
    1,625
    Thumbs Up/Down
    Received: 54/0
    Given: 6/0
    Since this is your first post, you probably have not read the sticky post about 'dreaded switching jacks'. If your amp has a Send and Return jack on the back, try plugging a patch cord between them. If this makes an improvement, your Return jack needs to be cleaned or replaced.
    Nov 2013
    139
    Thumbs Up/Down
    Received: 14/1
    Given: 1/0
    all the new amps are made with lead free solder,that has a tendency to fracture and most of the times leads to crackling/intermittent sounds.
    Try chop stick on joints all over the board and jacks.
    Senior Member Pedro Vecino's Avatar
    Jul 2006
    Spain
    511
    Thumbs Up/Down
    Received: 21/0
    Given: 13/0
    Your amplifier has a sliding selector on the back to bypass the loop. Sometimes they fail and do not make a good contact. It's the first thing I would look at.
  1. Mads Vox ac30c2
    By bacardi11 in forum Mods & Tweaks
    Last Post: 02-25-2017, 11:22 PM
  2. Vox AC30C2
    By pnut5150 in forum Maintenance, Troubleshooting & Repair
    Last Post: 09-03-2014, 04:08 PM
  3. Vox AC30C2
    By bsco in forum Maintenance, Troubleshooting & Repair
    Last Post: 02-25-2014, 06:59 PM
  4. VOX AC30C2 schematics
    By vintagekiki in forum Schematic Requests
    Last Post: 06-04-2012, 11:49 PM
  5. vox ac30,1972tb intermittent drop in volume?
    By rickmac in forum Guitar Amps
    Last Post: 01-05-2010, 10:06 AM
Tags for this Thread
