Results 1 to 7 of 7
Like Tree3Likes
  • 1 Post By eschertron
  • 2 Post By Mick Bailey
Thread: Under board connections
    Jun 2017
    England
    102
    Why are some of the connections on the turret board made on the underside ? Is it due to lack of space in the turret holes or would running them over the top interfere with the other components or is it to make it easier for the installation of the components ?
    Supporting Member
    Dec 2009
    UK
    3,191
    Often it's the most direct route and avoids running wires around components to get from A to B.
    Jun 2017
    England
    102
    So it's just a matter of convenience and if they were to be run over the top it wouldn't interfere with anything electrically?
    Aug 2012
    Great Black Swamp
    1,741
    I think it's more of the visual aesthetic that matters.
    When technical aspects are brought up, I read that the wires routed invisibly tend to cause frustration for the troubleshooter. Opportunities to make wrong assumptions about where the wires go, or if they are actually present at all!
    g1 likes this.
    Distortion is a form of signal degradation. It is pretty easy to define what a good "clean" signal is, but trying to achieve just the right kind of "broken" can be pretty maddening. - glebert
    Jun 2017
    England
    102
    That's what I thought but wanted to make sure and as I'm building my amp because I want a cracking guitar amp that sounds good I don't really care if someone from the amp police says they should be underneath plus I've got some lovely mil spec turrets that don't have holes underneath (Ha ha) so over the top it is
    Supporting Member
    Dec 2009
    UK
    3,191
    Is there a particular amp you have in mind? Generally you'd be OK but there could be exceptions. Established layouts are tried and tested and if you divert from those there may be unwanted signal or noise coupling that requires lead-dress experiments. Sometimes with an amp it only takes a few millimeters in a lead position to make a difference in noise or preventing or causing oscillation.
    g1 and d. spree like this.
  7. #7
    Jun 2017
    England
    102
    It's a basic dave hunter two stroke with the single 6v6 so nothing too technical there are only a couple of underboard connections (three in total) and I thought if I run them high enough away (using solid core) from other components following the same right angle theory it would be fine ?
  1. Question regarding pot connections!
    By Funkyman in forum Guitar Tech
    Last Post: 06-20-2013, 09:54 PM
  2. what temp for soldering PCB connections?
    By Groover in forum Guitar Amps
    Last Post: 05-21-2010, 04:26 PM
  3. Dumb question on rwrp connections
    By the great waldo in forum Pickup Makers
    Last Post: 08-27-2009, 09:52 AM
  4. Speaker connections
    By lmolter in forum Tweed Builders
    Last Post: 01-18-2009, 05:28 AM
  5. help with connections on RS Hygrade OT
    By HTH in forum Theory & Design
    Last Post: 10-12-2008, 11:03 AM
