Results 1 to 30 of 30
Thread: Last silly question
    Jun 2017
    England
    102
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    Last silly question
    Just want to make sure I've got this the right way round ?Click image for larger version.
    Probably the most embarrassing question I've asked!!
    0 Not allowed! Not allowed!
    Jun 2006
    California, USA
    3,468
    Thumbs Up/Down
    Received: 13/0
    Given: 10/0
    Scott,
    The wiring hookup you depict will work fine
    Some other relevant information to keep in mind is:
    * The switch you are using is a single Pole Single Throw unit. (SPST)
    * It is is not polarized so it will also work if you reverse the hookup of the brown and black wires. The "ON/OFF" label is just provided for convenience and optional use.
    * One thing to plan for is the physical orientation of the switch when you mount it on your panel. That is, decide if you want the switch to be ON when the toggle handle is flipped up or down or even to one side. This depends on the function you are controlling with the switch. For a power switch most people would choose it to be ON when the toggle is up of course.
    Cheers,
    Tom
    Jun 2017
    England
    102
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    I think that's what confused me? The switch seems to have slightly less resistance moving from on to off so I thought it would be better that way round
    Jun 2017
    England
    102
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    Although now i look at it again it's the same both ways so it must have been the way I was holding it !!
    Jun 2006
    California, USA
    3,468
    Thumbs Up/Down
    Received: 13/0
    Given: 10/0
    Quote Originally Posted by Jarvini View Post
    That describes a faulty switch.
    You should measure essentially zero resistance in one position and essentially infinite resistance in the other position of the switch handle.
    For any given position of the handle the resistance reading between the terminals should not change when you reverse the meter lead connections to the switch terminals
    Jun 2017
    England
    102
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    Sorry ignore the resistance part I meant physical resistance not electrical and after looking again it's the same
  7. #7
    Senior Member Malcolm Irving's Avatar
    Dec 2014
    Derbyshire
    364
    Thumbs Up/Down
    Received: 0/0
    Given: 5/0
    Quote Originally Posted by Tom Phillips View Post
    ... For a power switch most people would choose it to be ON when the toggle is up of course. ...
    That's the convention in the USA, but in UK the convention is the other way - down for on. Doesn't really mater - we are used to Fender amps etc. - just thought I'd mention it.
  8. #8
    Sep 2011
    Pace, FL
    1,485
    Thumbs Up/Down
    Received: 7/0
    Given: 4/0
    Quote Originally Posted by Malcolm Irving View Post
    Maybe that's why the standby switches always get me . It's different based on where the amps is from.
    nosaj
  9. #9
    Jun 2006
    California, USA
    3,468
    Thumbs Up/Down
    Received: 13/0
    Given: 10/0
    Yep. After I posted I thought that might come up. Especially for a chassis that is used both in combo and head amps with just a front panel change. Same reason that some amps have the guitar inputs on the left vs. the right side.
    Standby discussions can get complicated.
    "I was on/in standby"
    "I turned the standby off"
    etc.
  10. #10
    Chill-Ville, VA
    2,455
    Thumbs Up/Down
    Received: 14/0
    Given: 30/1
    Maybe instead of labels like "Play" & "Standby" and "On" & "Off" we should use
    "Boring" & "Awesome!" and "Happy Neighbors" & "Cops Are Here!"
    Justin
    "... If an older Boogie and classic Marshall had a (clearly illegitimate) child and you baked it in an oven set to clown shit crazy." - Chuck H. -
  11. #11
    Jun 2017
    England
    102
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    I'm from the uk and prefer up as on and down as off
  12. #12
    Dec 2008
    Wernersville, PA
    12,203
    Thumbs Up/Down
    Received: 3/0
    Given: 4/0
    I can't remember what newer amp it was but the standby switch was labeled "Standby" & "Standback"
  13. #13
    Supporting Member
    Staffordshire UK
    3,360
    Thumbs Up/Down
    Received: 7/0
    Given: 10/0
    I'm thinking that Marshall just copied that aspect of the Bassman (ie 'on' is with the switch flipped towards the bottom of the chassis) along with everything else, but then orientated the chassis in a head cab 'open side down', whereas Fender moved from 'open side vertical' with the tweed era to 'open side up' of the browns, BF etc.
  14. #14
    Jun 2017
    England
    102
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    I might post some pretty dumb questions but at least I give you all something to debate
  15. #15
    Lifetime Member Enzo's Avatar
    Lansing, Michigan, USA
    29,860
    Thumbs Up/Down
    Received: 66/1
    Given: 0/0
    I don't know about "copy", but I have never seen an amp where the power switch flips one way and the standby switch flips the other to operate. Whether it is facing up or down, it is always both in the ON position to play.
    In the USA, we generally think UP for on. The wall switch for my ceiling light goes up for on.
  16. #16
    Bent Member Chuck H's Avatar
    May 2007
    pacific north west
    13,032
    Thumbs Up/Down
    Received: 26/0
    Given: 33/0
    Yeah, but they also drive on the left side of the road. And walk backwards (I only heard this last part, not confirmed).
    "I'm just going to perform a bit more scientific investigation, turn it up to 11 and rip of the knob." überfuzz
    "A pedal, any kind, will not make a Guitar player more dangerous than he already is." J M Fahey
    "If you build it, it will hum..." Justin Thomas
  17. #17
    May 2007
    pacific north west
    13,032
    Thumbs Up/Down
    Received: 26/0
    Given: 33/0
    My ocd kicks in when someone changes one of my dual switch lights. You know, where there's a switch at either end of the room and when one is one way it means the other is opposite. If I never use one of the switches I arrange so up is on for the one I use. Then when someone changes my arrangement I have to walk over and flip the other switch so my world is right again
  18. #18
    29,860
    Thumbs Up/Down
    Received: 66/1
    Given: 0/0
    I remember when I was tiny, my dad finished the attic, and the stairs were newly wired with a light switch at top and bottom. My sister and I would man the switch at each end and "fight" for control. She'd turn it on and I'd turn it off. Then I tried to anticipate her flip so I flipped at the same time, and she had "no effect". I found it hilarious, she got pissed off. Tee hee.
  19. #19
    Jun 2006
    California, USA
    3,468
    Thumbs Up/Down
    Received: 13/0
    Given: 10/0
    I have always found it interesting that although there are only two switches involved they call it a "three-way switch" in electrician language.
  20. #20
    29,860
    Thumbs Up/Down
    Received: 66/1
    Given: 0/0
    Maybe on through one path, on through the other path, and off?
  21. #21
    Dec 2014
    Derbyshire
    364
    Thumbs Up/Down
    Received: 0/0
    Given: 5/0
    Quote Originally Posted by Chuck H View Post
    ... they also drive on the left side of the road. And walk backwards ...
    Yes. Walking backwards qualifies for a modest grant from the Ministry of Silly Walks.
  22. #22
    Supporting Member
    Dec 2009
    UK
    3,248
    Thumbs Up/Down
    Received: 10/0
    Given: 2/0
    Just a point on mains switching; best practice (at least in the UK) is to use a DPDT switch to switch both the live and the neutral. You cannot guarantee that the polarity of a mains socket or IEC cable is not reversed and a double-pole switch guarantees that the live will always be switched whatever way round the incoming mains is wired. Also, it's good practice to shroud all mains-side terminals using either heat-shrink sleeves, terminal covers or proper moulded flexible fuse and switch shrouds. This is to prevent accidental contact with the mains should the amp be worked on under power.
  23. #23
    Supporting Member
    Staffordshire UK
    3,360
    Thumbs Up/Down
    Received: 7/0
    Given: 10/0
    It's called 2 way switching over here.
    And toggle switches are unusual in electrical installations, rocker switches are the norm.
  24. #24
    Old Timer olddawg's Avatar
    Dec 2007
    Carlsbad, CA and Kona, HI
    2,607
    Thumbs Up/Down
    Received: 8/0
    Given: 0/0
    With a vertically mounted chassis (or a wall mounted light switch) I would assume that best practice would be off in the down position. It would seem much more probable to accidentally turn something off... which is better than accidentally turning something on for hours, days, years, and burning the place down. Especially back in the day.
  25. #25
    Feb 2010
    9,827
    Thumbs Up/Down
    Received: 49/0
    Given: 67/0
    Back in the day we had those push button wall switches.
    Certified Dotard
  26. #26
    Better Tone thru Mathematics bob p's Avatar
    Chicago, USA
    4,908
    Thumbs Up/Down
    Received: 37/0
    Given: 0/0
  27. #27
    Jun 2011
    Pittsburgh PA
    91
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    Quote Originally Posted by Mick Bailey View Post
    The only time I've ever been shocked while working on an amp was exactly this. Amp was off, but the cable was still plugged into the IEC connector and I just about jumped out of my skin. Heat shrinking all the mains connections is a very good idea that I will probably implement soon.
  28. #28
    Jul 2008
    Seattle Washigton USA
    60
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    Of course Marshall wires theirs as on when down. But they drive on the wrong side of the road as well.......
  29. #29
    Dec 2014
    Derbyshire
    364
    Thumbs Up/Down
    Received: 0/0
    Given: 5/0
    Quote Originally Posted by olddawg View Post
    ... I would assume that best practice would be off in the down position. It would seem much more probable to accidentally turn something off... which is better than accidentally turning something on ...
    I agree. I've sometimes wondered why we have 'down for on' light switches. Here's an interesting quote from Wikipedia:
    "The direction which represents "on" also varies by country. In the US and Canada, it is usual for the "on" position of a toggle switch to be "up", whereas in many other countries such as the UK, Ireland, Australia, and New Zealand it is "down". (In multiway switching, the correspondence between a single switch's state and whether lights are on or off depends on the state of the other switch[es] in the circuit.)"
  30. #30
    Jul 2008
    60
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    Well, I think I know why Marshall does it their way. Since they copied a tweed bassman for their first amps, the switch is in the same orientation as to the other controls and chassis. When you rotate the chassis 90 degrees it is now down.
  1. Replies: 11
    Last Post: 07-24-2017, 07:20 AM
  2. Silly Fender Schematic Question
    By Pryde in forum Maintenance, Troubleshooting & Repair
    Last Post: 11-30-2014, 07:06 PM
  3. Very silly capacitor question...
    By EFK in forum Theory & Design
    Last Post: 02-19-2011, 12:53 PM
  4. silly question about standby switch
    By vince76 in forum Maintenance, Troubleshooting & Repair
    Last Post: 07-31-2009, 05:30 PM
  5. silly grounding question
    By EETStudent in forum Maintenance, Troubleshooting & Repair
    Last Post: 02-18-2008, 06:05 AM
