Most of the production shops are probably using cnc laser or a stamping press to cut forbon. I'd recommend a Freud Diablo 40 tooth x 7 1/4" contractor's blade on a tablesaw to quickly and accurately rip the strips to width and cut those to length with a miter fence. You could then drill them in stacks using a fixture on your cnc and radius the corners of a stack using a corner rounding bearing bit in a router (while holding the stack together with dowels using the holes you just drilled).
Take how much is your time worth, divide by # sets of flatwork you can make an hour, add in materials and tooling cost. Compare to cost of finished flatwork + time selecting and ordering it + cost of shipping. Don't neglect to factor in the expense of downtime when your supplier runs out of something for months at a time...
LinkBack URL
About LinkBacks
