Results 1 to 4 of 4
Thread: 200S pictures
    Mar 2008
    Whitby Ontario Canada
    2
    200S pictures
    Hi Gentlemen, I am a new member and was wondering if anyone has pictures of the inside of a Sunn 200s.I would like to build my very first amp and I cant think of a better one. I have the schematic but I would like a picture of the board layout. If anyone could be of help or direct me to where I can find this info I would appreciate it.
    Thanks in advance
    Rob
    Supporting Member loudthud's Avatar
    Near Dallas Texas
    2,151
    The 200S is built on terminal strips with a laced wiring harness. Pictures won't do you much good because all the wires just disappear into a bundle of wire. Weber VST sells kind of a clone kit (6S100?) that is more of a eyelet board type layout. You can look at the layouts there. The Weber kit doesn't use the 6AN8, it uses an EF86 and a 12AU7 driving a pair of KT88s and a Marshall transformer set. It's about half way between a Sunn and a Fender.
    Mar 2008
    2
    Sunn 200s
    Thanks Loudthud, that gives me a lead to go on.
    Knob
    Cornelius, Oregon
    1,045
    If you go here http://sunn.ampage.org/ you can find out more info. This is the real Sunn forum where everyone hangs out at, including Conrad Sundholm, the co-founder of Sunn back in the day.
    I have some 200S pics I could email you later tonight if you wanted them? You could build a clone, and use the Triode Electronics transformers and get a very nice sound. If you do the layout the same as Sunn, it is VERY critical to get the layout and wire runs exacty the same or it will oscillate. If you build the circuit with a board, it will probably oscillate unless you locate the output transformer more like a Fender. They are a simple amp to build, and are best suited for bass, but can be prone to oscillate unless the layout is just right. Have fun!
    Send me a PM with your email addy if you want some pics.
    greg
  1. Amplifier Chassis Pictures - where is it?
    By Gregg in forum Maintenance, Troubleshooting & Repair
    Last Post: 01-25-2008, 11:35 AM
  2. Sunn 200S
    By gbono in forum Maintenance, Troubleshooting & Repair
    Last Post: 09-25-2007, 01:04 AM
  3. 200S Power Tranny
    By Rick Erickson in forum SUNN
    Last Post: 11-26-2006, 08:58 PM
  4. some pictures of my homebrew 5e3
    By riscado in forum 5 E 3
    Last Post: 08-31-2006, 03:18 AM
  5. Posting pictures so they, like, open
    By Ray Ivers in forum Lobby
    Last Post: 06-25-2006, 11:05 PM
