| | #1 |
| Junior Member Join Date: Jul 2008
| Broken GTEL84S (6BQ5) Tube - Works?
Hi, one of my Fender Blues Junior tubes seems to have broken down. It is one of the GTEL84S (6BQ5). The tip broke and the top is whitish. I do not understand too much of electronics, but have a doubt regarding why does the amp still sounds, as if nothing had happened (seems like) Is the 2nd bulb just a spare? Is it safe to still use it or should I get a replacement ASAP? thx, Ricardo |
| | #2 |
| Lifetime Member Join Date: May 2006 Location: Wise, Virginia
You've broken the tube and air has entered and the "getter" - a material within the tube designed to absorb some of the gasses left once the tube was evacuated - has now combined with all the gas it can and turned white. Stop using the amp until the tube can be replaced - and with this model you should probably replace them as a set. And don't waste your money buying fancy orange ink with gravy tubes - they are probably just silk screened sovwreks anyway. Get a good set of JJs and boogie on. Rob |
| | #3 |
What Rob said. The second tube is not a spare, both tubes work to make the speaker move. But when one tube quits, there is still one left to try and cover it all. You would notice it more the louder you play in most cases. |
| Bookmarks |
| Tags |
| 6bq5, broken, gtel84s, tube |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| Hickok 532 Tube Tester--How to test 6BQ5, etc. | Humber | Maintenance, Troubleshooting & Repair | 5 | 01-27-2009 05:23 PM |
| 6AQ5 vs. 6BQ5/EL84 | EETStudent | Theory & Design | 13 | 05-15-2008 09:39 AM |
| Amp works! | bluefoxicy | Build Your Amp | 0 | 04-14-2008 09:06 PM |
| zero ohms and it works? | dazzlindino | Pickup Makers | 21 | 02-11-2007 12:25 AM |
| Tube Works MV-962 schematic needed... | Jeremy | Maintenance, Troubleshooting & Repair | 0 | 01-17-2007 12:52 AM |
