| | #1 |
| Member Join Date: May 2008 Location: Tampa, FL
| Fiberboard mounting
Ok, it's time for another newbie (noob?) question: I have a nice 5F6A fiberboard and insulator, but I'm not sure of the recommended way to mount the board to the chassis. I imagine spacers are used between the chassis and the insulator board. What about between the insulator and the circuit board - spacers there, too? And do I have to drill my own mounting holes in the chassis? It seems that none of the pre-drilled holes match up. Progress note on my Bassman replica: I have most of the parts loaded on the fiberboard; I have all my filter caps loaded on their own board; I have a commercial chassis from Hoffman; Have sockets; All pots and jacks mounted on brass plate with some wiring; No tubes yet; No trannies yet (see another post about which iron to buy); No cabinet yet. Needless to say, I have a ways to go. Larry |
| | #2 |
You don't need any spacers between the insulator board & chassis, nor between insulator board & circuit board. "I have most of the parts loaded on the fiberboard" - Aaaah, I would have tackled the mounting hole problem BEFORE loading up the board, it's the first thing I do. You'll probably want to use the holes in the circuit board as your datum now. Transfer circuit board holes to the insulator board & drill thru, then dry mount the insulator on the chassis & drill new holes in the chassis if necessary. Hopefully this will save you drilling thru the circuit board from the chassis side & possibly taking out a component? Though, working from chassis holes forward is the way that I would have gone, you could still do this if you have spare components/don't mind a bit of remounting if necessary? Double check that board mounting screws do not short against ANY wires, even ground wires, on either side of the crcuit board. |
| | #3 |
Thanks for the reply. Luckily, the components are not yet soldered to the board. I can pull them out easily and then follow your instructions. But... there seem to be a lot of holes in the chassis already, but all I have to mount yet is the PT, OT, and choke. The tranny holes are obvious, but I'm not sure where the choke gets mounted. I also have the holes for the cap cover accounted for. I just want to make sure any holes I drill for the board don't conflict with some other part that has yet to be mounted. I know, I'm too cautious. However, since I might sell this amp, I don't want a hack job. Larry |
| | #4 |
Well, I just looked at the chassis again and all holes are accounted for. That's a good thing. However, the board slightly overlaps the mounting holes for the OT and cap pan, so I'm thinking maybe a small spacer to lift the board up a tad to clear the nuts. And how many mounting holes should I drill? 2, 3 (2 ends plus middle in a line), or 4?
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| Fiberboard cutting service? | achase4u | Pickup Makers | 2 | 01-11-2008 03:23 AM |
| Mounting speakers | Bernardduur | Cabinetry | 4 | 12-15-2007 12:23 PM |
| Shock mounting tubes? | Steve Conner | Theory & Design | 30 | 09-28-2007 05:12 PM |
| Z-mounting a stand-up | Matt T. | Theory & Design | 4 | 04-30-2007 01:49 PM |
| Is forbon similar to fiberboard? | Satamax | Pickup Makers | 2 | 03-08-2007 02:32 PM |
