| | #1 |
| Senior Member Join Date: Sep 2007 Location: Indialantic, Florida
| Vox 1143 question
I'm working on a 1967 Vox V1143 Beatle. The brilliant channel has about 5% output. All other channels are loud and clear. I took some measurements and found the bias to be off a bit (12V). I adjusted the bias pot on the preamp chassis to where I was getting about 15V (not 19V) on the preamp transistors. There's also around -6vdc on the chassis that contains the power supply and the output. The voltage reading on that chassis changes inversely when I adjust the bias. I'm feeling there's still a component issue someplace in the brilliant channel. Or possibly the mixer for that channel. Has anyone had a similar issue that they would like to share with me. Thank you, Gary Last edited by Garydean; 08-11-2008 at 06:09 PM. |
| | #2 | ||
| Old Timer Join Date: Jun 2007
| Quote:
Quote:
Beyond that, watch out for the reverb switch and associated wiring. If it is dirty it can kill the signal from either the bright or normal pre-amp. | ||
| | #3 |
Thanks Bill, I didn't have the signal jumper plugged into the preamp board when I took the readings earlier. It's now connected and -6vdc went away. Still a faint signal out of the bril channel. I tried scoping the signal thru the bril channel and my scope decided to quit on me. I'll investigate the reverb area. I tested all the other electrolytics and they measure good. The control I was adjusting seems to be the limit level control. What should that be set on? thanks!! Last edited by Garydean; 08-11-2008 at 10:58 PM. |
| | #4 |
| I'll have to look it up. You feed a signal into the amp and you adjust for something like onset of clipping. When I find the schematic and procedure, I'll scan it for you.
| | #5 |
Hey Bill, I replaced one of the non polar electrolytics, C120, and it's fixed. The casing was cracked but It looked fine until I removed it. Thanks for the help!! G |
| | #6 |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| What's the vox pathfinder ic? | wblakesx | Maintenance, Troubleshooting & Repair | 1 | 11-14-2008 12:05 AM |
| XLR to 1/4" for old vox head question | Garydean | Music Electronics | 1 | 08-10-2008 10:06 PM |
| Vox AC-30/6 TB problem | vegetable man | Maintenance, Troubleshooting & Repair | 8 | 07-23-2008 05:58 PM |
| VOX AD60VT Question | LtScheiskopf | Maintenance, Troubleshooting & Repair | 0 | 04-04-2008 10:20 PM |
| Question about a vox 1x15 bass cab | corduroyew | Guitar Amps | 2 | 12-08-2007 07:15 PM |
