| | #1 |
| Member Join Date: Jun 2008 Location: u.k.
| boxy sounding cabinet
Any advice for getting a good sound from a 2x12 guitar cab. Having built it myself, loaded it with a celestion Vintage 30 and a celestion G12-H, the sound i get is quite" boxy". Cab is driven by a Marshall JCM200 TSL100 valve amp and i use a Gibson Les Paul. Do the speakers need "playing in"? Certainly dont get as much top end to the sound that i used to from my 4x12 bwith celestion V30s in. |
| | #2 |
| Junior Member Join Date: Sep 2007 Location: New Mexico
More details please. Open or closed back? Parallel or series wired? A picture would help.
| | #3 |
| guitar cab boxy sound
drivers are 8 ohm, wired in paralell. Cab is sealed back.
| | #4 |
This is outside the scope of this forum but the internal dimensions of a sealed cab are critical to the end sound. If your design was a new one, this may be part of the problem. Adding a port or making it a semi-open back could help but that may not be the sound you're after. Also, check that the speakers are in phase. + and - wires going to the same terminals. That would serious mess up the sound. |
| | #5 |
| Senior Member Join Date: Jan 2008 Location: Galashiels, Scotland
Experimenting with different absorbent linings may help. Boxy sound can be symptomatic of reflections off the cabinet back wall coming through the cone.
| | #6 |
| Senior Member Join Date: Sep 2006 Location: Chicago
Also be aware of the fact that closed back cabs, which are known for more "punch" (low end), are also known to reduce "brilliance" vs. open back.
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| Best sounding SS amp you all have encountered? | Slobrain | Guitar Amps | 145 | 03-17-2010 10:24 PM |
| Good sounding transistor amps | Liam | Guitar Amps | 0 | 11-12-2007 01:07 AM |
| Amp sounding like an oscilator??? | Satamax | Maintenance, Troubleshooting & Repair | 6 | 01-03-2007 09:58 PM |
| 'thin' sounding effects | Brett Pearson | Guitar Effects | 3 | 12-09-2006 03:55 PM |
| It's A Mystery: Nasty Sounding Tube OD | heyniceguy | Guitar Effects | 1 | 11-02-2006 01:34 PM |
