Pre-war amp, not sure of make
  • #76
    Appreciate, but this field coil wiring would need 4 wires between chassis and speaker assy.
    Between chassis and speaker assy there are 4 wires; 2 wires for field coil and 2 wires for OT (compare sch and lay)
    Click image for larger version  Name:	2.gif Views:	0 Size:	21.3 KB ID:	926947 Click image for larger version  Name:	1.GIF Views:	0 Size:	492.8 KB ID:	926948
    It's All Over Now
    • #77
      VK, you're really eagle-eyed and alert .
      So the OP seems to be wrong (or I misinterpreted) about only 3 wires between amp and speaker.
      • #78
        Thank you
        It's All Over Now
        • #79
          Originally posted by thelonious_crunk View Post
          So I managed to get it working first try, i did 19 caps in 3 hours and used my variac to slowly bring her to life. This was pretty straight forward. Its great and fairly quiet from any noise. Definitely sounds good. All 4 inputs work. Will be looking for the matched tube set soon. Oh, and no shocks, just a small soldering burn on my middle finger
          Thanks for helping me
          Wow, that is like winning the lottery that it worked after just cap replacement. Seems like you did a good job on replacing them if it works so well.
          • #80
            Only thanks to all of the people in this discussion. I know it can be difficult to coach people online. Yes i agree, but i had an idea it would because the original seller said it worked 'not long ago". But we all know how that goes...
            • #81
              Well i see 3 terminals on the speaker, unless one is ground. The speaker connector going from the amp is 4-prong. Either way, you guys helped me stay on the right track with this
              • #83
                No doubt it is a 4-prong/4-pin plug, but the question is: How many wires are actually connecting to the plug?
                • #84
                  I see 4 on the other end as well. I see 3 leads are going to the OT. 1 goes to the speaker terminal. A couple wires also bridge a connection from the OT straight to the speaker terminals.
                  • #85
                    Please photo your speaker transformer both sides.
                    The speaker connector is on the bottom of the OT, on the top you see 3 wires of the OT (a1 / + HV / a2) and 1 wire of the field coil.
                    The other wire of the field coil is connected to the middle terminal of the OT.
                    On the speaker terminal you have 4 wire (see lay post # 76 and photo #78)
                    It's All Over Now
                    • #86
                      Possible one side of the OT secondary is soldered direct to the speaker frame, and one side of the voice coil is also.
                      • #87
                        I'm gonna send vintagekiki pics of it when i get home via email since my pics are too large from my phone on here
                        • #88
                          Oh, you can just look and tell us whether my notion is right or not.
                          • #89
                            Right
                            • #90
                              Click image for larger version  Name:	20210321_211428.jpg Views:	0 Size:	240.2 KB ID:	927124 Click image for larger version  Name:	20210321_211420.jpg Views:	0 Size:	274.5 KB ID:	927123 Click image for larger version  Name:	20210321_211445.jpg Views:	0 Size:	300.4 KB ID:	927125
                              Thank you
                              1)
                              Click image for larger version  Name:	Resize of 1.GIF Views:	7 Size:	423.3 KB ID:	927127
                              2)
                              Perfect
                              Pure natural antique clean sound, I haven't heard in a long time.
                              It's All Over Now
