Originally posted by ca7922303
View Post
EL34 Grid Stopper resistor
This topic is closed.
C16 should be between red mark and yellow mark. The red marked joint is the point of nfb injection in you circuit. Further you have a blue and green Mark's what I consider should be 100k nfb resistor solder points. You need to check somehow to be sure. Unfortunately you cannot broke the link without lifting the board as I see. The brutal crude intervention without lifting the board suppose to cut the track on board and to restore eventual with a wire link. I cannot recommend that, I have to think some else...till than do a cleaning with a tooth brush. I see some which seems solder rest between v6 pins"If it measures good and sounds bad, it is bad. If it measures bad and sounds good, you are measuring the wrong things."
Originally posted by catalin gramada View PostC16 should be between red mark and yellow mark. The red marked joint is the point of nfb injection in you circuit. Further you have a blue and green Mark's what I consider should be 100k nfb resistor solder points. You need to check somehow to be sure. Unfortunately you cannot broke the link without lifting the board as I see. The brutal crude intervention without lifting the board suppose to cut the track on board and to restore eventual with a wire link. I cannot recommend that, I have to think some else...till than do a cleaning with a tooth brush. I see some which seems solder rest between v6 pins
Originally posted by catalin gramada View PostCheck again in those points red and yellow, I posted the pic again. You should have the 100n cap in those position
blue and green points(0.0 ohms)
Rechecked 1st red and yellow points below P20(20.7nF).
I think maybe catalin wants to disconnect NFB to check OT phasing?
If so, maybe this is easier. The amp has a presence control. Is it working in the normal direction, or is it reversed? As you turn it up, the sound should get brighter.
(I'm assuming amp still works properly at lower volume settings)Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
Originally posted by g1 View PostI think maybe catalin wants to disconnect NFB to check OT phasing?
Originally posted by ca7922303 View Post
the amp is not at full volume, but does work at lower volumes, but just noticed the presence control has no effect on brightness or volume"Take two placebos, works twice as well." Enzo
