Old 11-22-2008, 06:24 AM   #1
Fender Bandmaster AB763 Vibrato problem
Anybody know how I can look at my OPTOISOLATOR to see if it is stock? The tube is fine that drives it but not vibrato. I'm going to crack it open tomorrow but wanted to get some tips on what to look for before I go in. Also if my osolator is bad who sells a proper replacement? Any good testing methods? Thanks again guys.
StratTone is offline   Reply With Quote
Old 11-22-2008, 09:20 AM   #2
Supporting Member
The Light-Dependent Resistor, which might need replacing, is shown in the attached .pdf document. (Was that your qn?) I think any LDR that can take 500V will work
__________________
Old 11-22-2008, 04:31 PM   #3
I've never acutally opened up the roach. What is the resistor value? So any LDR that will handle 500V will work? Value doesn't matter?
Old 11-22-2008, 05:03 PM   #4
Quote:
There is little or no voltage on the LDR, only audio from the second pre-amp output. The LDR grounds out the signal path to create the effect.
The "roach" is an LDR (light dependent resistor) and an NE-2 neon lamp bulb, coupled together in a heat shrink tube. If you can see the light flashing through the end of the heat shrink tube, then your LDR is suspect. Normally they will become very unresponsive and will not give you a very deep effect. Almost any modern photocell will work as a replacement, but due to reaction time, some will handle the fast speed settings better than others.
If you don't see the lamp flashing, then there is a problem with the circuit. Do you have a foot switch or shorting plug in the pedal jack? Is the oscillator itself running?
In all the years that I've seen these things I've only seen one neon bulb failure, and that was due to a broken lead.
52 Bill is offline   Reply With Quote
Lost power in Vibrato Channel Bandmaster jdwnyc Maintenance, Troubleshooting & Repair 8 03-19-2008 08:40 PM
Low output Fender Bandmaster Paul P Theory & Design 7 09-28-2007 08:53 PM
69 Fender Bandmaster reverb ohms output benindavis Vintage Amps 2 08-17-2007 08:50 AM
Bandmaster Reverb - Hum problem tubetonez Maintenance, Troubleshooting & Repair 13 08-10-2007 06:37 AM
ab763 bass problem lky Maintenance, Troubleshooting & Repair 19 12-11-2006 08:15 PM
