Old 01-24-2009, 12:01 PM   #1
Post Sovtek mig 50 Transformerchange II
Hello
Still needing help determining whitch trafos I need for my Sovtek mig 50.
Data
Amp : Sovtek mig 50 head orange edition (not midget)
tubes : 2x 6p3s (6l6) power
: 2x 6n2p preamp
: 1x 6n1p ph.Inv (i think)
ot - 4,8 and 16 ohms - 50 watts
pt - 230 volts primary. filaments 6,3 volts.
pcb - printed 007
I think i can determine the ot myself, as i've been told that any 50w marshall replacement ot will do. - (correct me if i'm wrong.)
But the trouble is determining whitch pt I need as there are several outputs needed for connecting the components in the amp (pcb, rectifier etc.)
Can anyone tell me what voltages I need on the secondary ?
Various schematics from the web doesn't seem to comply to my amp, also the have not the voltages printed on.
grateful from any help and/or comments
Poffa
Poffa is offline   Reply With Quote
Old 01-27-2009, 03:01 AM   #2
The output tranny needs to have a plate to plate impedance for a pair of 6L6 tubes. You may end up with a output tranny for a Marshall with EL34's.
"Tubes and More" sell a power tranny that would work. Look up a 290DX transformer. Of course you need to consider the physical size and mounting orientation. I'm assuming you have no low voltage devices like OpAmps or relays. I'm not familiar with this particular amp.
Twist is offline   Reply With Quote
Old 01-27-2009, 09:17 PM   #3
Thanks I'll check it up
Old 05-17-2009, 04:08 AM   #4
Mercury magnetics sells a replacement in the Axiom line: Mercury Magnetics - misc. amp transformers
it is very expensive though
tommy d is offline   Reply With Quote
Old 05-17-2009, 01:02 PM   #5
A few years ago, I bought replacements for a Mig100h from New Sensor for $25 each, power and opt. Maybe email them and see if they have any left.
Chrome Dinette is offline   Reply With Quote
Old 05-18-2009, 07:53 PM   #6
Wow...thats a screamin' deal if they're good quality.
Give unto me a bit of flooring under this fat floating sofa.......
__________________
Gtr_tech is offline   Reply With Quote
Old 05-18-2009, 10:42 PM   #7
WholeToneMusic's Avatar
New Sensors prices have gone up quite a bit.
__________________
Helping musicians optimize their sound.
WholeToneMusic is offline   Reply With Quote
Old 06-10-2009, 02:17 PM   #8
pyo
sovtek mig 50 transfo
Hey poffa,
I have the same amp: Sovtek Mig 50 orange edition.
Have you found which output and power transfo could replace the old ones?
Let me know if you have any news or any deals !!
Thanks
pyo
pyo is offline   Reply With Quote
Old 11-29-2009, 06:33 PM   #9
omi
PCB layout
I want to build Sovtek Mig 50 amp from scratch, would it not be too difficult for someone to take a high-res picture of the printed circuit board solder and components sides?
omi is offline   Reply With Quote
Old 12-01-2009, 12:22 AM   #10
All you need is the schematic to built the amp.
__________________
Tags
mig 50, sovtek, trafo, tranny, transformer
Sovtek mig 60 mods ? flcmcya Mods & Tweeks 1 11-23-2008 05:00 PM
Sovtek MIG 60 wui223 Maintenance, Troubleshooting & Repair 26 08-31-2008 09:07 AM
Sovtek Mig 50 k00chman Maintenance, Troubleshooting & Repair 4 08-19-2008 09:36 PM
Sovtek MIG 50 help please lowbrow Maintenance, Troubleshooting & Repair 5 04-25-2008 05:20 PM
Sovtek MIG-50 help insanezp Maintenance, Troubleshooting & Repair 6 02-25-2008 09:33 PM
