Old 01-31-2009, 03:37 PM   #1
1979 Fender Twin Reverb - can't turn off reverb
I have a '79 Fender Twin Reverb Silverface that worked fine for couple of months, a few days ago, I noticed that I can't turn the reverb off with the footswitch. I've checked the footswitch and it's ok. Please help, THanks.
pro1911a1 is offline   Reply With Quote
Old 01-31-2009, 04:14 PM   #2
mikeboone's Avatar
Does the reverb shut off when you unplug the footswitch?
How did you verify proper operation of the footswitch?
mikeboone is offline   Reply With Quote
Old 02-01-2009, 12:09 AM   #3
The reverb doesn't shut off when I unplug the footswitch. The vibrato side is working so I switch the plug and the vibrato is still working, also I test the footswitch with a multi-meter and they're all function properly. Thanks.
Old 02-01-2009, 12:22 AM   #4
bnwitt's Avatar
135 watt twin right? The reverb on/off is a simple circuit. The foot pedal basically grounds the grid of the recovery tube. Without the foot pedal the reverb would be on. If the foot pedal is making, then there must be a bad connection between the recovery grid terminal and the jack pin. I assume you can eliminate the reverb by turning it's control fully CCW right?
bnwitt is offline   Reply With Quote
Old 02-01-2009, 03:11 AM   #5
Yes, it's 135w twin. And I can eliminate the reverb by turning the reverb knob fully CCW. THanks much.
Old 02-01-2009, 04:10 AM   #6
I posted on this a while ago, I must have hit the wrong button.
When you ohmed out yoour stomp switch, did you measure it right at the switch terminals? What you need to do is go to the plug end of the footswitch cord - the shielded one, and measure resistance from the plug tip- to the outer contacts. Does it still off/on when the sdwitch is pushed? If not the wire connections are broken somewhere.
__________________
Old 02-01-2009, 11:02 PM   #7
mikeboone's Avatar
Having this info... make a shorting plug with an RCA connector or an RCA cable that you can sacrifice.
Plug it in and see if there is a change of state. After all you are looking to isolate where the problem lies.
Old 02-02-2009, 02:40 PM   #8
Problem solved, found a bad connection between the recovery grid terminal and the jack pin as bnwitt described. Thanks much.
Reverb Issues on a Fender Twin Reverb womantone Repair and Restoration 15 09-26-2008 05:31 PM
twin reverb doesnt turn on reverb Maintenance, Troubleshooting & Repair 2 06-30-2008 02:43 AM
Old Fender Twin Buzz in Reverb dstiner11 Maintenance, Troubleshooting & Repair 5 06-26-2008 04:25 AM
Help me care for of my 72 Fender Twin Reverb jlonigro Maintenance, Troubleshooting & Repair 2 12-28-2007 10:48 PM
Fender Twin Reverb Dano Music Electronics 4 10-23-2006 10:56 PM
