| | #1 |
| Junior Member Join Date: Jun 2008 Location: San Diego, CA
| Tubes losing power
Recently after about 5-10 mins of playing, my amp's power tubes will completely lose power. When it happens it kinda just fades out as if i was turning it off, but the power switch is still lit up. Just no power to the tubes. I swapped power tubes and the same thing happened; brand new pair of JJ el84's too. I was wondering what would cause this? Could it be a number of things? btw the amp is a crate VC 2110R Thanks |
| | #2 |
| Old Timer Join Date: May 2007 Location: pacific north west
Well, first, your assumption that the power tubes are losing power, and this is causing the volume drop, is based on what? You could also try a preamp tube swap and cleaning all the jacks before having to crack it open. Chuck |
| | #3 |
well they lose their glow. When it happens i can watch them do it, like i turned the power off. After this happens there is of course no output either. |
| | #4 |
The 6 volt AC power from the power transformer is not getting to teh tube sockets. A failing solder connection or a failing connector are suspects.
| | #5 |
cool ill look inside for anything that appears loose/disconnected Thanks tons |
| | #6 |
it may not look loose. But you could try wiggling things.
| | #7 |
yeah that seems to have been the problem I took it apart and made sure all the connections were ok. Nothing seemed real loose but its not doing it anymore. Thanks tons for the advise though! |
| Bookmarks |
| Tags |
| power transformer, tube amp repair |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| JCM2000 TSL Losing low End | dtd6string | Maintenance, Troubleshooting & Repair | 3 | 02-04-2009 02:17 AM |
| Arcing in power tubes | atmars | Maintenance, Troubleshooting & Repair | 11 | 10-04-2008 05:36 AM |
| My 65 Champ losing it's voice | vintageguitars | Maintenance, Troubleshooting & Repair | 10 | 03-19-2008 05:03 AM |
| Which power tubes to use? | Lizard King | Build Your Amp | 1 | 01-13-2008 04:55 AM |
| Troubleshooting after power tubes die. | Chill | Maintenance, Troubleshooting & Repair | 17 | 11-23-2007 08:52 PM |
