Go Back   Music Electronics Forum > Amplification > Guitar Amps
Guitar Amps General discussion about amps
Old 03-09-2009, 04:49 AM   #1
Help! my chassis is stuck half-way in my headshell!
I need to break the headshell now. Any advice? It got stuck b/c of the nuts I inserted at the top of the chassis and not enough clearance!
$2700 amp!
__________________
Rivera S120, Marshall JMP-1, EL34 dual monobloc
rabies is offline   Reply With Quote
Old 03-09-2009, 05:43 AM   #2
If you have a Rotozip or a rotary too. (Dremel, etc), I would cut a groove near the damaged side in pictures one and two. (On the side, not the top or bottom)
If you think it will be cutting it too close to the chassis, then cut a groove as far in as possible and use a chisel to open the rest until you have a groove cut through the wood side.
I would then try and spread the cabinet apart far enough to slide the chassis out. you could use a piece of wood or something to hold the cabinet apart while you slide the chassis out.
You might be able to repair the damage to the cabinet then and save some bucks on a new one.
That's my idea just going by the pictures.
vinman753 is offline   Reply With Quote
Old 03-10-2009, 12:29 AM   #3
thanks for the response.
I actually dropped it (on purpose) from a 2 ft ledge in my garage and it landed perfectly to break the small inner wood blocks that support the chassis when you slide it in there.
short story: alls good now, the amp works fine and I screwed one screw in the top back from support.
what bad and then good luck!
__________________
Princeton Chorus Breaks up on clean channel, chorus gets stuck... animal69 Maintenance, Troubleshooting & Repair 7 07-27-2008 10:38 PM
Stuck at power section Russ Debugging Your Build 23 06-22-2008 10:55 PM
Newbie question, Half Power? Stone Theory & Design 12 04-07-2007 05:04 PM
Half power sw. 496dart Build Your Amp 11 08-22-2006 01:52 AM
half a peavey classic 60/60! mocklah Maintenance, Troubleshooting & Repair 9 07-27-2006 11:52 AM
