Go Back   Music Electronics Forum > Amplification > Guitar Amps > Mods & Tweeks
Old 03-28-2009, 08:42 PM   #1
Converting from 6EU7 to 12AX7 ... need a little help.
Hi everyone.
As the title suggests, I want to convert an amp with a 6EU7 to a 12AX7. I have a nearly limitless supply of vintage 12AX7s but very few 6EU7s.
I've found the pinouts on tdsl and made a little conversion chart for my own benefit. The one question I have is that the 12AX7's 9th pin is designated as the center heater pin but there's no correlating pin on the 6EU7, so I don't know where to go with that.
Below is the chart I made for myself.
I'm doing this to a '65 Gibson Skylark GA-5T. I have the schematics for that up on my site as well if anyone wants them.
Thanks for any help you can offer, I greatly appreciate it.
sangandongo is offline   Reply With Quote
Old 03-28-2009, 11:33 PM   #2
Supporting Member
When running a 12AX7 on a 6.3V heater winding, pins 4 & 5 are tied together on one side of the heater winding, and pin 9 is on the other side of the heater winding. So you need to run one wire from pins 4-5 of the 12AX7 to either pin 1 or pin 2 of the 6EU7, and the other wire from pin 9 of the 12AX7 to the other pin (2 or 1) conversely.
__________________
Old 03-29-2009, 12:10 AM   #3
So, if I understand you correctly, the correlation would be like this (using the relationship table on my chart). Makes sense to me if that's right.
12ax7 - 6eu7
1 = 6
2 = 5
3 = 4
4,5 = 2
6 = 7
7 = 8
8 = 9
9 = 1
Thanks for the answer so quickly, by the way.
John
Old 03-29-2009, 10:10 AM   #4
Supporting Member
Sounds about right if you've got the pins numbers right. Check here
http://www.triodeel.com/6eu7p1.gif
__________________
Old 05-01-2009, 11:37 PM   #5
Quote:
12ax7 - 6eu7
1 = 6
2 = 5
3 = 4
4,5 = 2
6 = 7
7 = 8
8 = 9
9 = 1
John
Did this work out for you?
I am contemplating the same thing in a Minuteman GA-20RVT
Your help appreciated in advance.
thanx
Roland is offline   Reply With Quote
Old 05-02-2009, 04:57 AM   #6
Yes and no.
The OT was actually dead, so even though I rewired the preamp section for 12AX7, the amp ended up shitting itself anyhow. SO, yes, it worked and sounded great for a few minutes, but the real issue was the output tranny, so I'm going to have to rewire that in later.
j.k.
Gibson GA19, 7199 ver, 6EU7 cathode cap capnjuan Repair and Restoration 18 05-24-2008 03:23 PM
6EU7 vs. 12AX7 EETStudent Mods & Tweeks 5 05-13-2008 04:12 PM
converting old radio for guitar use milothicus Conversions 3 03-27-2008 01:50 PM
12AX7 vs 6EU7 power draw ricach Mods & Tweeks 4 01-10-2008 03:42 PM
converting Bandmaster to Tweed Fred G. Mods & Tweeks 7 06-04-2007 03:24 PM
