| | #1 |
| Junior Member Join Date: Apr 2009 Location: Baltimore Maryland
| HELP! Vox BerkleyII , Reverb suddenly stopped working?
The reverb on the Vox berkley II suddenly stopped working. ?. Does anyone have any idea where i should look first? Thanks in advance |
| | #2 | |
| Old Timer Join Date: Jun 2007
| Quote:
First thing to check is the tank and the wires going to and from the tank. Start by twisting each of the RCA plugs that enter the tank to make sure that they are making good contact. If that doesn't fix it, remove the tank from the amp and check the wires that connect the RCA jacks to the transducer coils. | |
| | #3 |
Thanks 52 Bill! I really appreciate your help, and the quick response |
| | #4 | |
| Supporting Member Join Date: Jun 2008 Location: Italy
| Quote:
http://www.schematicheaven.com/voxam...y_II_v1081.pdf Just to complement what Bill said, you can also check the transducer coils too by measuring the transducer coils' winding resistance, you should have a few tens ( LO-Z reverb tank ) a few hundreds ( MED-Z reverb tank ) or 1 to 2 KiloOhms ( HI-Z reverb tank ), if you read "open" on either side then either that coil, or the internal connection between the RCA socket and that coil, is open. Hope this helps Best regards Bob
__________________ Foolproof equipment is hard to design, because fools are VERY ingenious... Last edited by Robert M. Martinelli; 05-21-2009 at 11:26 AM. | |
| | #5 |
| You folks are great!
Thanks to all!, You folks are great!
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| Roland Jc-120, Reverb is not working | lobo_sito | Maintenance, Troubleshooting & Repair | 2 | 02-16-2009 10:41 PM |
| twin reverb trem not working | keysersoze808 | Maintenance, Troubleshooting & Repair | 3 | 04-17-2008 08:20 AM |
| Fender Stage160 Reverb not working | Rpasman | Maintenance, Troubleshooting & Repair | 10 | 04-13-2008 07:37 PM |
| Marshall VS-265 reverb not working | baumtracks | Maintenance, Troubleshooting & Repair | 1 | 08-30-2007 11:44 PM |
| Ampeg B2 - Stopped working. | frankthompson@37qs.freeserve | Other Amps | 11 | 10-18-2006 12:33 PM |
