Go Back   Music Electronics Forum > Amplification > Guitar Amps > Vintage Amps
Old 06-01-2009, 06:40 PM   #1
Question Help - Tremolo Opticoupler Needed
Hi. I need help in finding a suitable replacement to my tremolo opticoupler in a 1969 Guild amp. The original failed neon/LDR is a Clariex Photomod CLM4120A. I found a Fender Vibrolux opticoupler from Antique Electronics for under ten bucks. Could I just use this as a replacement without adverse effects. Thanks
loumur is offline   Reply With Quote
Old 06-02-2009, 03:36 PM   #2
Supporting Member
Hi,
did you mean Clairex?
try this link, they claim they have the "original thing" in stock.
Clairex In-Stock Parts Catalog Page 1
Hope this helps
Best regards
Bob
__________________
Foolproof equipment is hard to design, because fools are VERY ingenious...
Robert M. Martinelli is offline   Reply With Quote
Old 06-02-2009, 04:14 PM   #3
Tremolo optocoupler
Yes, that's it. Great find, I did a google search with various keywords and didn't find this vendor. I really appreciate your help!
Thanks
-Lou
Old 06-02-2009, 07:28 PM   #4
Tremolo optocoupler
Robert - FYI on 4StarElectronics
I just contacted 4star, they quoted me $40USD for the optocoupler. That's not the bad part. I found out that they (along with other obsolete electronic parts dealers I subsequently found) have a minimum order qty (4star is $100 per line item).
When I compare the purchase of an OEM part to using the Fender Vibroverb part as a possible substitute for $10USD, it's hard to justify spending $120 (w/o shipping). Maybe it's worth the experiment. I guess the other option is to use a Perkin Elmer Vactrol, but it's LED driven, and I'd have to modify the circuit to drive the LED, versus the ~100V neon bulb.
Old 06-04-2009, 06:41 AM   #5
Supporting Member
Hi,
I'm sorry to hear that, I find their policy to the least questionable, but let this sleeping dog lie.....
If memory serves me well, the "old type" vactrols Fender used back in the old days were made by ( quite obviously ) an LDR and a neon lamp, just like the original Clairex, so chances are the one you found will work.
It's also possible that it won't work exactly as the old one did, though, and some circuit tweaking might become necessary; should this be the case, it would be useful to find both LDRs' datasheets to help you in modding the amp.
Hope this helps
Best regards
Bob
__________________
Old 06-04-2009, 12:36 PM   #6
That's what I'm now thinking. I'd have to determine the properties of the replacement LDR in order to match characteristics as best I can. The amp is from 1969, and I'm trying to restore it. It's in such great shape that I really don't have much to do. Again, appreciate your help Bob.
Lou
Thumping Tremolo tubeswell Debugging Your Build 10 04-21-2009 08:25 PM
Help my amp now has tremolo.... Steel Duck Tweed Builders 7 03-11-2009 02:43 PM
Weak tremolo due to low grid voltage off tremolo tube? slidincharlie (Carlo P) Maintenance, Troubleshooting & Repair 5 02-05-2009 06:32 PM
SS tremolo gbono Maintenance, Troubleshooting & Repair 10 12-15-2008 09:04 AM
Weak tremolo drewl Maintenance, Troubleshooting & Repair 4 08-08-2007 03:23 PM
