Hi mbratch, I've got a 5E3 with a Heyboer transformer, and right now mine is running a 5U4 rectifier with a pair of 6L6GC's, a 275 ohm cathode resistor. The voltage at pin 3 of the output tubes is, if I remember, right around 375vdc. Sounds really nice, and it runs very warm, hot enough to not hold the power transformer for more than 5 seconds or so. But so does my '68 Super Reverb...it is right around the same temperature. The chassis on the 5E3 gets nice and toasty but it won't scorch the tweed
I've run it for several hours at a time without issues. I guess one thing to check would be to make sure the low voltage heater windings are holding their respective voltage levels up, and not sagging. If they are, you should be okay. I remember when I started in electronics that I was astonished how hot transformers would run in those old tube tv sets...
LinkBack URL
About LinkBacks
