Old 07-27-2009, 10:07 PM   #1
Eden WT-300
I have an Eden WT-300 amp that works fine but the output limit light comes on at 31VAC RMS or 240W @4ohm if my calculations are correct. Does this amp have a problem? Its rated 300W@4ohm. I've had Mesa tell me plus or minus 30% is acceptable.
clintronics is offline   Reply With Quote
Old 07-28-2009, 01:32 PM   #2
Supporting Member
Hi,
your calculations are correct, but.....
Are you measuring the RMS power by playing through the amp and taking your readings across the speaker or are you doing it on the bench using a 4 Ohm dummy load instead?
I'm asking this because the dummy load, being a resistor, has the same impedance over the whole spectrum of frequencies, while a speaker's impedance is not constant.
Another scenario : The overload protection circuit's threshold could be set too low and the limiter could trip at a lower power.
300 W RMS on a 4 Ohm dummy load means you should be able to get some 34.6 V(RMS) across the load's terminals. Anyway, keep in mind that from a "sonic" ( SPL ) point of view, all other factors being the same ( speaker, cab etc. ) with some 240-250 W you're only less than 2 dB away from the amp's maximum SPL, so it doesn't make much of a difference IMHO.
Nonetheless, I have to disagree about the fact that being 30% off the rated power is to be considered "normal". This means I could sell ( or advertise ) a 40W RMS amp as if it was a 60 W RMS one, and that could be hardly considered fair IMHO.
Hope this helps
Best regards
Bob
__________________
Foolproof equipment is hard to design, because fools are VERY ingenious...
Robert M. Martinelli is offline   Reply With Quote
Old 07-28-2009, 07:40 PM   #3
Dummy load
200hz into a 4 ohm dummy load.
BTW im not making up the mesa story. I had a 2 6L6 amp that was putting out 35watts and mesa told me that was OK because there was so much margin of error because of the many people they had making OP transformers for them at the time. This was 10 years ago when I used to do warranty work for them.
eden wt 400 blaise Guitar Amps 19 10-20-2009 07:24 PM
Need Eden Traveler 400 schematic Twist Schematic Requests 6 08-09-2009 08:28 PM
Eden Metro 2 ohm load problem rf7 Maintenance, Troubleshooting & Repair 0 06-03-2009 07:36 PM
Eden Nemesis crossover hookup question tim Maintenance, Troubleshooting & Repair 6 02-06-2009 01:43 AM
Eden wt-400s hum/buzz Funkerator Maintenance, Troubleshooting & Repair 4 01-04-2009 02:04 AM
