| | #1 |
| Junior Member Join Date: Jun 2006
| Electronics Problem
So i bought a schecter 006 pre-moded. It has a coil tap with a couple of EMG's buckers. My problem is that my guitar loses almost all of the gain even though the volume and tone is at turned all the way up. It sounds like it would if the volume was almost all the way down. Any guesses?? Thanks |
| | #2 | |
I had an ESP strat copy with a set of EMG-SA pickups in it that had a similar problem. It turns out that the chip in the the SPC control had blown. When I replaced the SPC control with a new one, it was fine. HTH, steve Quote:
| | #3 |
| Pickup Maker Join Date: May 2006 Location: Montclair, NJ
Have you put a fresh battery in the guitar? I'm assuming those are the active EMG's and not the HZ models. It might also be a wiring problem... but it sounds like a dead battery. I'm curious about the coil tap, because you can't tap EMG's... unless it's one of the two pickups in one case models.
__________________ Those who create are rare; those who cannot are numerous. Therefore, the latter are stronger. - Coco Chanel www.sgd-lutherie.com www.myspace.com/sgdlutherie www.myspace.com/davidschwab |
| | #4 |
yeah the battery was that first thing i tried. i can't tell ya much about the coil tap part because my friend who knows a bit more electronics told me that part when he looked. oh i forgot to say its got a pull-push boost on the volume knob. suppose this is what happens when you buy a pre-upgraded guitar.
| | #5 | |
| Quote:
__________________ Those who create are rare; those who cannot are numerous. Therefore, the latter are stronger. - Coco Chanel www.sgd-lutherie.com www.myspace.com/sgdlutherie www.myspace.com/davidschwab | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
