Go Back   Music Electronics Forum > Amplification > Guitar Amps > Theory & Design
Old 10-14-2009, 03:45 PM   #1
unused PT filament windings?
I'm looking at the Hammond Transformer listings and it seems most of the time I see a suitable voltage and current capacity for the power tubes that the transformer also has 5vAC heater leads.
It seems that there aren't many suitable B+ with 6.3vAC choices that do not also include 5vAC.
That's great if you are running a tube rectifier.
What do you do if you want to assemble a bridge rectifier out of diodes?
Do you just terminate or find a use for the 5vAC leads? Shrink wrap? A Pilot light?
thanks,
mike
mike_mccue is offline   Reply With Quote
Old 10-14-2009, 03:50 PM   #2
Old Tele man's Avatar
...ALL unused windings should be taped/insulated and otherwise left alone.
__________________
Old Tele man is offline   Reply With Quote
Old 10-14-2009, 04:05 PM   #3
Supporting Member
Yep I put a couple of layers of heat-shrink overlapping the bare end of each unwanted wire, and tuck the ends away somewhere where they ain't going to cause grief (but keep the wires there for a rainy day).
__________________
Old 10-14-2009, 04:47 PM   #4
thanks.
Old 10-15-2009, 12:53 AM   #5
Personally, I prefer to have the unused wires terminate on a terminal strip. But that is just another way of keeping them out of the way of everything else as suggested above.
__________________
Old 10-15-2009, 03:22 AM   #6
How about using plastic insulated twist connector nuts. One for each wire.
Diablo is offline   Reply With Quote
Old 10-15-2009, 03:30 AM   #7
Quote:
...unless those "house electrician twist nuts" are firmly tied-down somewhere, they'll "rattle" like mad inside a chassis when vibrated.
...shrink tubing and tie-wraps work well.
__________________
Old 10-15-2009, 03:40 AM   #8
The bottom line is this, no matter how you do it, you want the wires secure, and unable to touch something else electrically. The transformer itself doesn;t care at all whether you actually use the winding or not.
__________________
Unused 5v PT winding Rockn Build Your Amp 15 08-12-2009 04:52 AM
Unused triode Sir Cuitous Theory & Design 20 06-02-2009 04:15 AM
unused 12AX7 triode - ground unused pins? HTH Theory & Design 25 06-07-2008 12:23 AM
loose windings Dr. Guitar Pickup Makers 4 10-07-2007 01:31 AM
Unused 1/2 -12ax7 studioit Theory & Design 7 10-01-2007 04:36 AM
