| | #1 |
| Junior Member Join Date: Jul 2009
| Power output switch?
Hi, I've recently completed building a 5E3 and love it. I do find it too loud for practice, but i do see all the volume being useable at some point! I wondering whether I could a switch to select two different cathode resistors? At present I have a 330 Ohm and it gives me around 14 watts. I am thinking of putting a 600 ohm on a switch to lower the power output when all the volume is not required! Would this work? Thanks in advance for any input! |
| | #2 | |
| Junior Member Join Date: Oct 2009
| Quote:
| | #3 |
It won't have the effect that you are looking for, the tone may become thin & sterile, operating voltages in the amp will rise & the amp may sound harder, less warm. Your cathode resistor does not set the wattage of the amp's output (measured in AC Watts RMS), it sets the dc W plate dissipation (how much current the tubes take before going pop). Oftentimes, backing off the plate current will mean that you have to turn the amp up more to get a driven tone, the amp can actually come accross as louder, but not necessarily pleasantly so. In extreme cases, a larger cathode resistor may push the B+ voltage beyond tube & cap ratings. |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| power/standby in one switch? | acorkos | Maintenance, Troubleshooting & Repair | 5 | 07-10-2009 03:30 AM |
| How can I set this up to switch between two output tubes? | vg3000 | Build Your Amp | 5 | 01-01-2009 11:07 PM |
| ampeg v4 buzzing output with just power switch on | randomair | Maintenance, Troubleshooting & Repair | 10 | 08-30-2008 12:56 AM |
| Marshall 100w JMP (2203) - output switch | Sir Cuitous | Maintenance, Troubleshooting & Repair | 7 | 01-14-2008 03:14 AM |
| Anyone Have a Sunn Power Switch ? | Amp Kat | SUNN | 2 | 06-15-2007 02:14 PM |
