Hi Glen,
I once repaired one of these amps belonging to a friend, and, though I didn't like the way it sounded, I don't remember it as being terribly noisy....
I agree that the amp doesn't have a "real" problem, and what little hum is there, it's an issue only because the amp is being used for studio recording.
I think the "problem" could be due to poor/cheap/insufficient preamp's power supply voltage stabilizing/filtering ( good for "amateur" use but not good enough for "professional" use ) rather than a ground loop though.
I'd advise you to mod the preamp's power supply by removing the 15V zeners, cutting the positive/negative PCB rail and throw in a couple of 7815/7915, as they are better stabilizers than any zener diode could ever be, and they also have an excellent ripple rejection ratio. I'd also improve the filtering for the preamp section by "souping up" the filter caps. A couple of 100 nF poly caps between each stabilizer's in/out terminals and GND are not out of question. At this point the problem should be at least greatly reduced, if not eliminated. I have sometimes added small caps (100 to 220 nF) between each op-amp positive/negative supply and GND (as close as possible to the relevant op-amp) and this has helped with some very "hard to die" hum issues.
I did all of the above on various SS amps in the past with very good results.
JM2CW
Hope this helps
Best regards
Bob
LinkBack URL
About LinkBacks
