| | #1 |
| Junior Member Join Date: Nov 2009 Location: Bergheim, FRANCE
| New designs for a diaphragm pickup (yet another ampeg baby bass thread)
Hi there, I have been carefully reading the two posts on diaphragm pickups, or scroll / baby bass ampeg pickups. I have been considering building my own, due to 1) lack of original or even copied ampeg baby basses in my area (overseas, out of the reach of the "salsa" zone) 2) the fact that this is the standard for latin music bass sound 3) the pickup that originally comes with my cheap Chinese upright completely sucks. I am not however a purist, and I have been considering doing some departures from the original design. I am curious to know what knowledgeable people might think about them. I have even recognized some of what I thought were my own ideas in some of what has been covered in this forum (like attaching something to the diaphragm, thus extending the idea of "rivets" from the original design). * First possible departure: do we really need two separate diaphragms? How about using one big diaphragm covering a big portion of the top plate of the bass, however keeping the original idea of sensing the movement at the two bridges feet? Would this in your opinion increase or decrease the canceling effect of having one foot "out of phase" with the other? The "big diaphragm" would in certain modes vibrate so that one half goes up as the other goes down, thus cancelling the signal generated on the pickups, is that right? I would love to hear your opinions about this matter. * Second point of possible departure: I have always thought of "improving" the original design, if not in sound quality, at least in output level. A lot of water went under the bridge since the 1960's when these basses were made, and for instance nowadays neodym magnets are available. In electrical guitars or basses having a magnet that is way too powerful would disturb the string's ability to vibrate... but on an upright, with many pounds of tension on each string, I guess the effect of additional "muting" by using powerful magnets would be barely noticiable. * Second point of departure, extended: Then, since neodym magnets are available that are very strong, and yet don't have a lot of mass, why don't we couple them with the vibrating part of the system? I thought of two possible desings, but since I don't know too much about magnetism, I don't know which could work better. In both designs there is one ring magnet attached to the vibrating diaphragm (by means of a bolt going through the axis of the magnet), and another magnet, static, attached to the coil. The difference between model-A and model-B is that in the first one the vibrating magnet is thin and long and fits inside the coil, while the static magnet surrounds the coil. In the latter, the vibrating magnet is the opposite, like a coin, and vibrates on the top of the bobbin, and another magnet, static, is placed at the bottom of the bobbin. If I'm right, this pickup (in either model) should produce much more output than the original, since the magnetic flux would be increased considerably. Any comments would be much welcomed. Last edited by xxxchange; 11-07-2009 at 11:57 AM. Reason: corrected my lousy spelling, and rewrapped the text more in the lines of mr. Schwab |
| The Following User Says Thank You to xxxchange For This Useful Post: | Stealth (11-07-2009) |
| | #2 |
| Further clarification of the graphic
I had some bad experience in trying to convey ideas with my graphics (sometimes you think something is very clear to you, but it looks rather confusing to others), so I thought I would add some more text to explain it further, and improve the original graphic by adding a legend that explains what is what in the graphic. We see the two models I described in the first post. The cut is diametral, as if you were slicing a cheese in two parts. The magnets used are small neodym ones, of the ring type (a cylinder with a hole in the middle), probably around 5 to 15 grams in weight for those attached to the diaphragm, and a little bit more for the static one that is attached to the bobbin. The magnets have been axially magnetized. The difference between both designs is about the orientation of the magnets. |
| | #3 |
| Senior Member Join Date: Dec 2008
Hello xxxchange; From my experience with diaphragm-style pickups, I think your ideas are fine and workable. You're going to have to build test models and do experiments. As I mentioned in the other threads, almost everything with the tonal characteristics of a diaphragm pickup is in the mechanical characteristics of the diaphragm mechanism. The coil and magnet play a very small part. Regarding single vs dual diaphragms, the main reason Ampeg used two small diaphragms on the Baby Bass was to keep the pickup system compact. A single diaphragm to fit under both feet of the Baby Bass bridge would need to be roughly 7" (178mm) diameter. You can certainly build a system with a single large diaphragm, but it will take some experimenting with the spring rate vs the travel. The bigger diaphragm could potentially capture lower frequencies, but it also may have much more pronounced harmonics problems. You're going to have to work with it. The "mystery" pickup in Ampeg's horizontal Scroll Basses (AEB-1 & AUB-1; 1966-1968) uses a single diaphragm. It's about 5" (127mm) square, and has an effective diameter of 4 3/4" (120mm). It's made of 2 layers of 0.030" spring steel. On your magnet and coil designs, just don't go too far trying to make them powerful. If you create too large of a signal level, the amp is going to clip and distort. And to properly load the amp, the coils should have a resistance in the range of 5K to 10K ohms. Just to give you a reference point, the system in my AUB-2 Scroll Basses has two coils with a total of 10K ohms resistance, and two 1/4" x 3/4" Alnico V magnets that move within the coils. That gives plenty of signal level in a passive circuit. So, don't go crazy adding magnets! I really doubt that you'll need the stationary magnets that you have shown in your drawings. The moving magnets, particularly neo's, should have all the field strength that you need. |
| The Following User Says Thank You to Bruce Johnson For This Useful Post: | xxxchange (11-08-2009) |
| | #4 | |
| Senior Member Join Date: Nov 2007 Location: Barnegat,NJ
| Quote:
In a diaphragm-style pickup the mass of the diaphragm and whatever is attached to it will play a major role in determining which harmonics are emphasized. The xxxchange design proposal is a classic moving magnet type of design. Another way to try this with less mass (a moving coil) is to make a very light, pancake type of coil, single layer, glued to the diaphragm with a fixed, adjustable, strong neo magnet underneath each bridge leg. The coil could be in the approximate range of 4 to 8 ohms impedance and then connect to a small transformer 4 or 8 ohms to 20K or 50K to bring the level up to the 100 to 200 mv level for an amplifier input. The coils can even be series or parallel humbucked to help reduce hum. Since it is only the vertical motion of the coil that induces the most voltage, xxxchange can try nonmagnetic diaphragms that have the least mass and enough strength and compliance to produce a good tone and harmonic balance. Just some food for thought. What do you think? Joseph Rogowski | |
| The Following User Says Thank You to bbsailor For This Useful Post: | xxxchange (11-08-2009) |
| | #5 | |||
| Quote:
I'll take your word, since you have been already experimenting with these pickups, and concentrate on the "mechanical" side of the question, rather than the electronics. I had been considering other materials for the diaphragm, since the use of magnets will make the use of steel as a diaphragm material no longer a pre-requisite. But frankly I haven't got any great ideas. I don't know a lot of physics, so I don't know which materials might be better, I don't know what physical properties it has to fulfill... I guess springiness... and lightweightedness are things too look for. Some kind of silicone rubber, maybe? But it won't withstand the huge pressure from an upright bridge. What I was considering is, since I've read somewhere that the idea behind a diaphragm pickup was advertised as if the steel would "mimic" the vibration of the fiddle plate... well, to use the classical lutherie technique of two cuts at the side of the diaphragm, to make the plate vibrate more freely (just like the "f-holes" in a fiddle). Another thing one can learn from the 500 year old violin design is to have the diaphragm arched, so that it can withstand more pressure without loosing flexibility. Quote:
From what I have gathered, the diaphragm system adds some weird harmonics quite low at the spectra, so that basically you need to pass the sound of the bass through a lowpass filter, and leave that weird metallic resonance out. The frequency for that filter is quite low, so the usable range of the baby bass is very limited. But perfect for salsa music, which needs a percussive, fundamental and boomy sound. I don't know if this is true, I am basing myself in what I've been reading, because of lack of first-hand experience. I don't know if that applies either to the scroll-bass. At any rate, maybe the use of a bigger diaphragm could worsen the problem if the weird resonances appear even at lower frequencies... because the usuable range could be even more limited. Quote:
Thanks again for the advice! | |||
| | #6 | |||
Thank you for your contribution to this thread. Quote:
What I figure, I could isolate the parameters one by one, bore a diaphragm size, and start experimenting with different materials, all of the same diameter. First to come to mind: well, steel of course, the original design... and the reference for others to compare. Maybe I could also try wood, as in the even more original design of the renaissance, but I don't know if it could work with such reduced dimensions. Quote:
The idea of the moving coil and static magnet (an not the other way round) would be the correct one, I grant you that, but it also needs someone with more skill than myself to construct. That would be the usual dynamic-mike or speaker approach, more or less. I reversed that because I thought that just 5 grams of added mass at each bridge foot won't affect the sound too much, but maybe it does. Quote:
But, do you have any ideas so as to which materials could be great for the task? I would gladly hear about that. Better options for diaphragm material. It's also a matter of preference, I guess. E. g., I know I don't like the sound of hard woods for bass construction, but rather the resonances of ash and maple alone. At any rate, it seems that I cannot do without some --ehem-- tedious experimenting, if I am set to find "the sound". Well it's being digested right away | |||
| | #7 |
| Supporting Member Join Date: May 2006 Location: Glasgow, Scotland
How about titanium for a diaphragm? Re the low-pass filter thing, to get a fundamental boomy sound: Harmonics are what allow you to distinguish one instrument from another. If you're going to filter them out, then you can start with any sort of bass guitar at all, and the result will sound the same.
__________________ "Transformerless is the way to go", said he, without a hint of irony. |
| | #8 |
| Pickup Maker Join Date: May 2006 Location: Montclair, NJ
Yeah, real upright basses have a lot of harmonics, and not all that much fundamental. But I guess the baby bass doesn't really sound like an upright... it's more of a thump.
| | #9 |
| | #10 | |
| Quote:
The thing is, when an upright is played in a band, the pop and warble is the main thing that you can hear over the roar. It's percussion with tone. For the Salsa guys, that's what the bass player does and wants. The diaphragm pickup of the Baby Bass is made to create that pop and warble, which you can't really get out of typical electric bass with a magnetic pickup. The Baby Bass does a good job of the pop and warble, but no, it's steady tone isn't nearly as rich as a real upright. It's not going to compete with an upright in solo studio work. But, on stage in a club, playing Salsa and heavy rhythmic music, the Baby Bass is the king. It's funny, because when Everett Hull and the Ampeg guys developed the Baby Bass in the early '60's, their intention was to make a portable replacement for the upright, for use in light jazz combos. That's the music that Everett loved and played. But, over the decades, the Baby Bass found its own niche market. | |
| The Following User Says Thank You to Bruce Johnson For This Useful Post: | xxxchange (11-10-2009) |
| | #11 | ||||
Thanks again for another valuable contribution. Quote:
I have seen one 18th century book on mechanical instruments, in which the author compares the sound produced by musical instruments with syllables: there's always a consonant (i.e. , pure noise or mixture of noise and sound) followed by vowel (i. e. sound, tone). Different instruments or playing techniques and articulations, don't produce only different "vowel" sounds, but also different "consonants". All happens at that unsteady, chaotic instant in which the instrument sounds begins. Then everything sort of gets stabilized. Quote:
It takes a lot of practice to reverse that paradigma. And yet however you cannot play well latin music until you really understand that. The very best latin musicians have an acute sense of rhythm that -IMHO- no other musicians can rival at. Listen to the pianists Peruchin, Chucho Valdes, or bassist Cachao, or Tito Puente, or any other master and you'll get the idea. The notes happen right where they should, they never settle with anything less than rhythmic perfection (yet it never sounds mechanical). The downside is that as great as they are in rhythm, well, intonation is not the house special. I remember one Cuban bassist, as a bass guitar player I could tell he was a double bass player that took a bass guitar. He confirmed my suspicion as I had a talk with him after the concert. He had taken the bass guitar to avoid the trouble of traveling with a double bass, but he hated it. In his words: whenever you play the double bass I can stop strings carelessly, but with this instrument I have to really watch out for where the notes are. So for the latin bass player the harmony changes are just an excuse for producing different "colors" of "thumps", "pops" and "warbles"... (not that I'm there myself, I'm still strugling to get rid of unnecessary decorations, like anything too melodic sounding). Quote:
Regarding the competition between an acoustic double bass and a Baby Bass, I think there shouldn't be any at all. From what I've seen, people never ask a Baby Bass to produce acoustic sounds, and they don't play them with a conventional double bass technique. At least not the bassist I have seen live: he had very low tension strings -no steel- on it -nothing like real double bass strings- and deflected the strings so much it nearly looked like someone doing archery. Plus, you could only guess within the minor third which note he just played, but the "when" he played was something you just could not ignore. What you may call a slap-in-the-face sound. Quote:
Anyway, taste is something that depends on culture. And even the "shortcomings" of certain designs might become desirable in time. | ||||
| | #12 | |
| Quote:
I should have payed more attention to the physics professor, but I just couldn't stand him. I am trying to catch up, but I think I missed the train already. Could you recommend me some sources to understand the theory behind the instruments' electronics? | |
| | #13 | |
| Thanks for the tip on titanium. What are the physical properties that make titanium an elegible material, by the way? I don't know if it's comercially available over here, I'll check. Quote:
And I emphasized in my last post why it is so important, more than any harmonic spectrum in the steady sound, for latin music. Now, as I recall the Baby Bass produced quite an -unexpected- good sound when bowed. I guess the pickup dissipated the sound very quickly -while playing pizz- and that's why it produces such a sudden but short burst of sound, with less than optimum note pitch definition and harmonic richness. But if you are constantly feeding it with more energy, like when bowing, it might -as said, haven't heard it myself- sound well. | |
| | #14 | ||
| Quote:
Quote:
| | #15 |
| Senior Member Join Date: May 2006 Location: Boston, MA area
| Where is "over here"? Please update your user profile to give the city and country, as it helps greatly when answering many kinds of questions.
| | #16 |
Titanium is a really light, strong and springy metal. It's roughly as light as aluminium, but as strong and elastic as steel. Seems like just the thing for making a diaphragm out of. It's expensive too, but you wouldn't need much of it.
| The Following User Says Thank You to Steve Conner For This Useful Post: | xxxchange (11-10-2009) |
| | #17 | |
| Quote:
I live in beautiful Alsace, by the German border, but -thanks to both WW and all their participants- now under French rule. Quite a beautiful place, especially if you were born in a big, dirty and grey city -as in my case-. | |
| | #18 | |
| Quote:
| | #19 |
| Senior Member Join Date: May 2006 Location: PDX
Alsace wine and southern German food, not bad either.. I've made the train trip from Paris to Basel many times. Pretty countryside as you get closer to the border. So instead of titanium, why not spruce and/or carbon fiber cast in a bowl shape? Pure Ti isn't very strong, only the Al4V6 alloy really has the characteristics you want. You'll probably want to experiment with other fibers like kevlar and spectrol to get the unique sound profile that fits the music. That said, spruce is a well understood material that's readily available. Don't discount that fiberglass body as a part of the sound of the babybass. |
| The Following User Says Thank You to David King For This Useful Post: | xxxchange (11-13-2009) |
| | #20 | |
| Quote:
Running down the center is a 3' long piece of 2" x 2" x 1/16" wall aluminum tubing. The tang of the neck plugs into the top, the whole diaphragm pickup assembly bolts to front partway down, and the tailpiece and peg fit into the bottom. The acoustic structure of a Baby Bass is an aluminum tube surrounded by hard foam, a blend of ding and thud. It could qualify as sophisticated engineering or cheezy construction, depending on your viewpoint | |
| The Following User Says Thank You to Bruce Johnson For This Useful Post: | xxxchange (11-13-2009) |
| | #21 | |
| Quote:
| | #22 |
"A reasonable man adapts himself to suit his environment. An unreasonable man persists in attempting to adapt his environment to suit himself. Therefore, all progress depends on the unreasonable man." -- George Bernard Shaw. |
| | #23 |
| Well, actually I'm not very fond of German beer, it's too bitter -IMO-. There's one unfiltered one, hefeweizen, which is sort of acceptable -always my own personal opinon-, other that it's so thick you don't know if you should have it with a spoon. It's not the beer man talking here -more like the red wine in my case- but the ones I like the most are Belgian. I've been to Brugge for a concert once, and the Belgians have some really tasty beer (and quite strong, also). Moving to French food, well, certainly not bad at all, but overrated. I like France a lot, but if you go to Italy you can eat a thousand times better for the same price. Anyway, I don't need anything too fancy looking for dinner. Having been born in Argentina, I'm used to eating meat twice a day, with only salt as seasoning... let's better change the subject or I'll get homesick. |
| | #24 | ||
| Quote:
Regarding wine, I am completely surrounded by vineyards, beyond where my eyes can reach. People grow vines even within the town, in every little corner. Too bad their speciality is white wine. They have some reds too, but they are not like the stronger ones that fit my personal taste better. Quote:
Is all that stuff at the reach of a complete profane? If anyone knows where to get that stuff within the European market, please let me know. Regarding spruce, that would be the most classical approach. The thing I don't like about it is that if you want a rugged instrument, a diaphragm of spruce, thin enough to vibrate, would be quite delicate. | ||
| | #25 | ||
| Quote:
I love unfiltered Belgian ales! I just finished a Hoegaarden. Quote:
| | #26 | |
| Quote:
I have read somewhere that the thing of filling the hollow with urethane insulating foam was to avoid the dreaded feedback problem that any air cavity could produce. Since it seems they didn't pick the materials for their "nice sounding" qualities, it would be pointless to leave that air space within the bass. That being said, the new baby basses, or copies on the original model, that are being built today in all the salsa-zone are mostly made of fiber-glass. I don't know if they still fill them with something, but I guess it's very likely. You could reverse the original design principle and try to build an instrument with some resonances. It would be like a dobro baby bass, with the diaphragm doing some acoustical work, appart from driving the microphone. But most people want the baby bass not for it's unplugged sound anyway, but for its ability to produce heart-stopping pops and warbles, in your words, that you can amplify at any sound level without the hassle of feedback. (People that would go through the hassle of amplyfing an acoustic instrument, they'll probably pick the traditional double bass anyway) | |
| | #27 | |
| Quote:
No doubt that people that want more of a real upright tone can use something like an NS bass, but those don't do what the baby Bass does either. I guess the body was cosmetic, huh? The bass was pretty much a metal pipe with a neck! Is the bridge/pickup mounted to the pipe or the body? | |
| | #28 | |
| Quote:
That plate, I believe, is bolted on the body of the instrument. I didn't know of the existence of that pipe until Mr. Johnson brought it up. | |
| | #29 |
| Cancellation problems.
I have been doing some research on how the bridge vibrates. It seems that the diaphragm pickups, as wired on the Baby Bass, rely on the two feet adding up, so in the case of one going up as the other goes down, destructive interference will occur. From what I have seen on the web, on analysis of how an acoustical instrument vibrates, the main motion of the top plate, where the bridge is standing, is up and down. Rocking or lateral motion of the bridge might be present, but I guess it is not what sets the plate into motion. So as a whole the Baby Bass design seems adequate, in that it assumes that both feet will move sort of "together", and not one against the other. I have found something that relates to this. I have been checking the book "The Physics of Musical Instruments", and it seems as if the two feet of an acoustic instrument bridge vibrate more or less with the same intensity for lower frequencies, but then some differentiation occurs, when a certain frequency is reached. That seems quite weird at the beginning, but then not: This might be due to the effect of having a bass bar in one foot, and a soundpost in the other one... not our case... I guess no one ever conducted any testing on how the two discs of a Baby Bass vibrates... although it could be done, maybe with some stroboscopic device or laser sensors. Anyway, the rocking motion of the bridge, however important or not it might be, can never be sensed by the Baby Bass PUs. |
| | #30 |
Yes, the whole pickup system is assembled to the cast aluminum plate, including the diaphragms, coils, controls, output jack, and wiring. The plate appears to attach to the body with 3 screws, but if you look inside, there are three bent aluminum brackets which are bolted to the aluminum tube spine, and come up under the body skin, providing the pads and threaded holes for the screws. It's solid metal from the pickup to the spine. Inside, the brackets are usually partly surrounded by the sprayed-in foam. If you took the brackets out, the body would cave in under the string load. As I said, the front and back of the body are made from thin flexible plastic. I believe they were vacuum-formed. A serious problem with Baby Basses is that the plastic has become brittle over 40+ years. On many of them the body starts developing serious splits, and there's really no good way to repair them. You can put in glue and patch plates on the inside, and then it just splits again right next to it. Yes, many of the recent Baby Bass-style clones, such as the ones by Steve Azola and Ray Ramirez, use fiberglass for the body shells. It's simpler to make in low volume, and more repairable. Steve's Baby Basses were the most authentic in construction, with the aluminum tube spines and foam insulation. I think Steve only makes the Baby Basses on special order these days. His main business is all kinds of his own design electric uprights, with wooden bodies. |
| | #31 | |
| Quote:
The two Baby Bass coils are wired out of phase from each other. This means that most of the output signal comes from the rocking motion, not the up-and-down motion. This is intentional. The rocking motion of the bridge is the dominant source of the pop and warble on an upright bass. The bridge rolls about an axis defined by the shape of the top, the soundpost, and the bridgebar. One of the keys to replicating the pop and warble in a percussive pickup system is in is getting the correct balance between the spring rate in the rocking direction and the spring rate in the vertical direction. This is where it can get tricky. | |
| The Following User Says Thank You to Bruce Johnson For This Useful Post: | xxxchange (11-14-2009) |
| | #32 | |||||
| Quote:
Quote:
Quote:
Quote:
Quote:
| | #33 | |||
| Quote:
In an acoustic instrument the rocking motion of the bridge is accentuated by the leverage effect created since one bridge foot is sort of stationary... I thought that the absence of soundpost would make the two feet vibrate sort of in unison. Well, I guess you could wire the coils so that the pickup is more sensitive to the up-and-down motion, but that would not yield the sought-for Baby Bass sound, according to your experience. Quote:
Quote:
Actually, even some other bridge movements are present, although not efficiently transfered to the instrument plate normally... you could eventually build a pickup system to sense those... What is the spring rate? Sort of the "springiness" or "elasticity"... the bridge's tendency to either favor one or the other movement? What kind of measures would you take to ensure you favor the rocking motion? Is there anything you can do from the standpoint of design in order to bring one or the other to the fore? For instance, I've read somewhere, I don't recall where -I will have to look again-, that the distance between the bridge's feet was essential to tune the frequency response. This might play a role here as well. Which parameters affect in your opinion the tendency of the bridge to favor one or the other way of vibrating? For instance, having the feet close together, and a high bridge is better I guess, than having a short bridge with the feet further appart... ? Sorry to ask so many questions, but you really got me thinking with that last piece of information. | |||
| | #34 |
The string's movement feeds the bridge movement which feeds the top's movement and vise versa all the way back to the string. You'll have inertia and drag and resonances acting and interacting at each step. I think it's going to be very hard to think this one though without getting dirty first. Let's remember that the baby bass was designed first and foremost to be easy to mass produce at a good profit margin. I don't doubt that the designer knew what he was doing but I doubt he knew exactly what he was going to get on the first try. They may well have adapted a few aspects to meet expectations and they may also have hit some dumb luck along the way. Are you equally concerned with arco as with pizz sound? |
| The Following User Says Thank You to David King For This Useful Post: | xxxchange (11-14-2009) |
| | #35 | |
| Quote:
I agree with you, at the end of the day, you have to "get dirty", some questions cannot be answered based on theory alone, I guess. There are far too many intervening factors interacting with each other to be able to discern which would be the optimum construction beforehand. Now, regarding the original design, I don't know if it was dumb luck, but they certainly created something with appeal for bassists looking for a percussive and fundamental bass sound at ampeg. Well, I already bought the steel plate, wire and magnets are on the way (sort of, I have to decide the gauge of the wire and the exact shape of the magnets). I will see how it turns out. Too bad that I don't have an original to compare it with, but I'll post the results here whenever they're available. I don't need a lot of luck to beat the cheesy sound that my Chinese electric upright produced right out of the box (lousy piezoelectric pickup). Thanks for all the feedback | |
| Bookmarks |
| Tags |
| ampeg baby bass, diaphragm pickup, pickup design |
| Thread Tools | |
| Display Modes | |
| Help finding screw - 10-32 thread, half thread, set screw | belwar | Pickup Makers | 38 | 10-05-2009 06:34 PM |
| Diaphragm-pickup from the old ampeg baby bass | mafguitars | Pickup Makers | 34 | 06-09-2009 12:43 AM |
| Schmatic for SWR Baby Blue 2? (or just Baby Blue..) | wizard333 | Schematic Requests | 2 | 06-02-2009 07:38 AM |
| Any tips on where to find an Ampeg-style baby bass magnetic diaphragm pickup? | mturkis | Pickup Makers | 16 | 01-27-2009 10:48 PM |
| Noiseless Pickup designs | Spence | Pickup Makers | 20 | 01-02-2007 11:02 PM |
