| | #1 |
| Junior Member Join Date: Sep 2009
| Mystery OT and impedance help
Hi, I just spent 3 hours surfing the net and found no complete answers; HELP!!! I have an output transformer from an old PA amp and need to ID the leads. This is a PP tranny with CT. I found a number of articles about using a test power source and measuring voltages to determine the turns ratio, but no one speaks to the PP CT tranny. I don't know if I should just bypass the CT? Or read using the CT and only 1 end of the primary??? Also I read where a 6L6 tube wants to see 4k to 5k impedance, again is this on half of the OT??? Also I was thinking of using 4 6V6's for power tubes, so how do I calculate the impedance of 1 pair in PP with a second pair??? Every thing I've read so far has confused the issue. Any help would be greatly appreciated Thanks D |
| | #2 | |||
| Old Timer Join Date: May 2007 Location: pacific north west
| Quote:
Quote:
And, FWIW, that 4k to 5k primary is more typical in post 1962 or so guitar amps than any other tube gear. And early guitar amps often used values more typical of other gear. 6600 is likely the most common primary impedance for a pair of 6L6's. But Fender and others found that they could get more power (at elevated harmonic distortion content) by using the lower 4k ish primary impedance. It's a slightly different feel and sound between the two. But just think tweed era vs. BF era Fender and you'll get SOME of the idea. Of course there were many differences between the preamps in either era too. Quote:
6V6's like pretty much what 6L6's do. Except that 6L6's handle lower primary impedances with more aplomb. When guitar amp companies started running 6L6's at 4k primaries they seemed to keep higher numbers for the 6V6's. But for most amps up to, again 1962 or so, 6L6's and 6V6's both used about 6600 primary for a pair. So, if the above "example" tranny were determined to be good for a pair of 6L6's at 8 ohms for a 6600 primary, there is no reason the same tranny couldn't be used for 4 6V6's into a 4 ohm load with a 3300 primary. Get it??? It's all about the turns ratio and the capacity of the transformer. HTH Chuck | |||
| | #3 |
And while we are at it, do you happen to know WHAT old PA amp it came out of? If we knew that, or even just what tubes it was associated with in the amp, then we'd have a pretty good idea what the transformer was all about.
| | #4 |
Thanks for all the help and so fast! Actually the tranny is still in the amp, but its missing the name plate. The leads are cloth insulation, so there are no colors to help. At one time it had an octal socket for outputs, but that has been butchered and a phone jack added to 1 lead It appears there are 2 ground leads and 3 taps. As opposed to applying voltage to the secondary, couldn't I just apply voltage to the primary with a wall wart and measure each tap?? Thanks again D |
| | #5 |
| Supporting Member Join Date: Feb 2007 Location: Wellington NZ
| If you do that you probably won't get any/accurate enough VAC measurement on the secondary.
__________________ Building a better world (one tube amp at a time) Last edited by tubeswell; 11-09-2009 at 07:01 PM. |
| | #6 |
Consider that the primary normally converts like 100-200v of signal down to 10-20, so your wall wart will step down to a very low figure that way.
| | #7 | |
| Senior Member | Quote:
One forumite mentioned keeping a wal wart with alligator clips soldered on for just such a purpose! I have pages and pages of data from all of my recycled/spare transformers. If all that data is bunk I think I'd have to give up on building amps altogether! Wanna buy some inaccurately cataloged parts? Sorry to hijack! | |
| | #8 |
In my defence I was considering a typical 9V to 15V supply, which at say 29:1 would make the secondary read .31V to .51V and I wasn't thinking about the millivolt setting when I replied before. My bad
__________________ Building a better world (one tube amp at a time) |
| | #9 | |
onward with the thread! jamie | |
| | #10 |
Having said that there still might be an issue relying on a millivolt reading on a secondary winding for accuracy when leakage inductance (which causes the voltage to change with loading) is taken into account. I've never tried the walwart on the primary myself. I have always used it on the secondary, so I've never verified its accuracy. I must pull out a few Ots this w/e and see.
| | #11 | |
OOps, too late to edit too... I said: Quote:
Chuck | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| ot primary impedance question | mikhett | Theory & Design | 1 | 05-10-2009 07:34 AM |
| Proper OT Impedance for AC30CC | trevorus | Guitar Amps | 2 | 03-06-2009 10:34 PM |
| OT impedance for P-P 6L6's | rf7 | Theory & Design | 4 | 08-24-2008 11:26 PM |
| Tweed Vibrolux OT impedance | Crawfish | Vintage Amps | 2 | 08-27-2007 02:05 PM |
| OT primary impedance on a Deluxe Reverb | Shea | Vintage Amps | 2 | 07-20-2007 06:07 PM |
