Is there a problem with the replaced speaker, or are you looking to make this original?
The original 4 wires that went to the speaker were 2 wires from the output transformer secondary to the voice coil (these are hooked up to the new speaker), and 2 wires that went to the field coil (basically just an electromagnet that replaces a permanent magnet).
Now this is where there may or not be something wrong with the speaker replacement: Was the original field coil used as a choke in the power supply or not?
In general terms, there are 2 types of field coil speakers that can be considered either high or low resistance. Low resistance types will measure in somewhere around 100 ohms and are wired in place of a power supply choke. If the original speaker was one of this type, then the power supply would either need a new choke or a power resistor to replace the missing field coil.
The high resistance types will measure in the 1000's of ohms and will be wired across the power supply from the high voltage to ground. If the original field coil was one of this type, then the wires can just be unhooked and insulated, with no need of replacement.
So, where do the additional wires on your amp go?
LinkBack URL
About LinkBacks
