Results 1 to 2 of 2
Thread: PEAVEY BRAVO 112 crunch channel bad switch?
    Dec 2009
    Denver, CO
    1
    Just picked up my third one of these amps, and found that when the ultra gain pull switch is engaged, the tone becomes thin, crackling, and extremely shrill, cutting in an out. Clean channel and all other amp functions fine. Already changed v2 out, and no difference. Seems like problem only relates to switch in the pulled out position. Any advice? Thanks very much!
    Senior Member Enzo's Avatar
    Lansing, Michigan, USA
    18,242
    Well, if it isn;t the tube, start following the signal through the amp.
    Check the plate and cathode voltages at each stage through the bad channel. Check the solder under any controls for that channel, and for that matter the controls themselves.
  1. +++need schematic peavey bravo 112+++
    By tortoto in forum Schematic Requests
    Last Post: 09-07-2011, 05:41 AM
  2. independant adjustable bias 4 peavey bravo..please help
    By ampstepper in forum Mods & Tweeks
    Last Post: 09-17-2009, 12:59 AM
  3. adjustable bias 4 peavey bravo.
    Last Post: 09-06-2009, 10:27 PM
  4. fssshhh noise on crunch channel above half gain
    By otto in forum Maintenance, Troubleshooting & Repair
    Last Post: 12-11-2007, 08:56 PM
  5. H&K Triamp Crunch Channel
    By Gregg in forum Theory & Design
    Last Post: 06-20-2007, 01:45 AM
Tags for this Thread
