Results 1 to 5 of 5
Thread: Crate GTX212 Squeals on power up
    Senior Member booj's Avatar
    Jun 2008
    556
    About a 1k rail to rail square wave on power up. Power supplys look good. (+/- 37 volts with nominal or at least the same ripple on both rails). No noise in the preamp section and their +/- 15 volt supply is good. Oscillation is only present at the power amp stage. Looks like it has been serviced before and the outputs were replaced with ST TIP142's and 147's
    I don't have a schematic. That's the next step.
    Anybody had a similar problem or have a scat?
    Thanx!
    ...Seems I can't figure the right way to do anything 'til I've exhausted all other possibilities...
    Dec 2008
    Wernersville, PA
    5,369
    Crate GTX212
    I had a GK RB800 that did the same thing.
    Never did figure it out
    Built a 3 second delay/on relay circuit for the speaker.
    Jun 2008
    556
    Boy, I wish that would work! This never stops though. It's as if the input is connected to the output. Just hjave to wait for a scat.
    Dec 2008
    Wernersville, PA
    5,369
    Crate GTX 212
    Did you try inserting a stereo plug into the FX insert?
    This should kill the preamp signal.
    If it still oscillates, it is in the power output section.
    I have attached the GLX series amp.
    The output section may be the same as the GTX (or close)
    Hope this helps.
    Attached Files Attached Files
    Jun 2008
    556
    found it
    The heatsink of Q19 which is connecxted to the differential pair was shorting to R57 which is a resistor in the input circuit. Loud technology sent a scat within 2 days of my request.
  1. Crate VC120 no power
    By jefe in forum Maintenance, Troubleshooting & Repair
    Last Post: 09-21-2010, 02:46 AM
  2. Fender FM212R Squeals at 4ohms, but not 8?
    By parentheticalfact in forum Maintenance, Troubleshooting & Repair
    Last Post: 11-13-2009, 06:40 AM
  3. Peavey C30 squeals
    By pulsar705 in forum Maintenance, Troubleshooting & Repair
    Last Post: 03-23-2009, 03:30 PM
  4. Marshall squeals like a pig
    By Monkeyfart in forum Maintenance, Troubleshooting & Repair
    Last Post: 08-25-2008, 08:21 PM
  5. Amp squeals at hi gain
    By txstrat in forum Maintenance, Troubleshooting & Repair
    Last Post: 08-07-2008, 08:43 PM
