Results 1 to 10 of 10
Thread: Peavey CS-800 -- Keeps Blowing Fuses
    rs_
    rs_ is offline
    May 2010
    19
    Hi, I've got an old 4U Peavey CS-800 that I bought as-is. The previous owner claimed it worked when I bought it.
    It keeps blowing fuses, almost instantly on powerup. This does not happen if only Channel A's power is hooked up, and it does happen if only Channel B is hooked up, or if both channels are. I also swapped the channel boards and the "B" board is the only one that causes failure.
    I tested all the transistors on Channel B and found one to be bad, so I replaced it -- and the fuse blowing still occurs.
    I'd appreciate any suggestions on where to go from here!
    rs
    Lifetime Member Enzo's Avatar
    Lansing, Michigan, USA
    29,152
    OK, so power amp B is blown, but powr amp A by itself will work, right?
    By channel board do you mean the little driver board with the row of pins along one edge, roughly the size of a pack of guitar strings? Are you saying that if you plug the B driver board into the A power module then A starts blowing fuses?
    Or does module B blow fuses with either driver card?
    First, go to the output terminal posts. Measure resistance between them. Are the B posts shorted together? When a channel blows, it often shorts the protective triac which is on the output terminals. If the red and black posts are shorted together, then you probably have a shorted SAC187 triac on the circuit board they are soldered to.
    There are two rows of power semis on the module heat sink. Most are outputs, but the end one of each row is a driver transistor. Check each one for shorts. There are also a bunch of 10w ceramic resistors. Mostly low resistance like 0.33 or something. Check ALL of them for opens.
    There is a diode on the heat sink with two wires running from it up to the driver board. Make sure it is not open. It is a dual diode, so the voltage drop across it will be twice what would be "normal."
    rs_
    rs_ is offline
    May 2010
    19
    Yes, I guess I am referring to the driver card. And the driver card from Channel B will blow fuses, regardless of which power module it is hooked up to. The driver card from Channel A will NOT blow fuses, regardless of which power module it is hooked up to.
    As for the semis on the heat sink, I tested them all and found one open (it was an output, not a driver on the end), and replaced it. The problem persisted even after I replaced it.
    I will check the diode, the ceramic resistors, and the triac, then post back.
    Thanks!!!
    rs
    rs_
    rs_ is offline
    May 2010
    19
    The ceramic resistors and diode are fine. The output posts do short, however.
    Is it most likely that the protective triac on the output board failed as a result of the failed output transistor?
    Thanks,
    rs
    Jun 2007
    4,960
    Quote Originally Posted by rs_ View Post
    Yes, quite common failure. The amp can be tested temporarily with the triac removed from the circuit.
    29,152
    Yes, remove the shorted triac, it is right next to those red and black posts. Now you can service the amp. Replace the triac when the rest of hte amp is working.
    If one of the driver cards causes trouble wherever it goes, then if no transistors are shorted, I'd be looking for an open in the bias string.
  7. #7
    rs_
    rs_ is offline
    May 2010
    19
    Hi, sorry it took so long to get back -- had to take a break from the project.
    I removed the protective Triac from Channel B. I hooked up the Channel B driver card back up in its original place -- any transistors that tested bad have already been removed and replaced with good ones from Channel A. (Channel A is not receiving power at the moment.)
    I also tried swapping out the Driver Boards.
    The fuse is still blowing, in the exact same fashion as before. What should I be looking for now?
    Specifically, what and where is the Bias String?
    Thanks,
    rs
  8. #8
    29,152
    The bias circuit is on the driver card, plus the little two-wires from that card back down to the diode on the heat sink board.
  9. #9
    rs_
    rs_ is offline
    May 2010
    19
    I will check the diode on the Channel B heat-sink board -- but since I swapped the driver cards, shouldn't that rule out anything on the driver card itself?
    Thanks,
    rs
  10. #10
    29,152
    You're right, I wasn't thinking.
    The bias circuit is on the driver card, but that diode on the heat sink is part of it. Of course that particular diode doesn't travel with the driver card. SO if the good card will make that heat sink assembly work, then the heat sink must be OK, including its diode.
    Let's review. As it stands you have one driver card that is bad and one that is OK. And we have determined that the triacs on both output terminal post boards are either OK or removed, right? And did we determine that both heat sink assemblies will work with the good card? or does one of those still have a problem too?
    Look at the schematic. Two transistors on the card are called drvier transistors. They are really pre-drivers, since the drivers are on the heat sink, but that's OK. When one of these cards blows fuses, I check every darn semiconductor on it. The transistors AND the diodes. If any transistor was burnt out, then look for open resistors associateed with it.
    Note there are pairs of transistors wired in parallel - Q3 and 5, then Q4 and 6. Those are difficult to test in the circuit because of all the parallel junctions.
    When troubleshooting, disconnect the wires from the triac board. We don't need nor do we want a load until the fuse thing is cured. With no load, the output can swing to DC without blowing a fuse. No load, no current drawn, the amp sits ther with 50v on the output. But if it still blows fuses that way, we can assume both polarity outputs are being turned on at the same time. And that generally means the bias has let go.
    From the base of Q9 to the base of Q10, Cr11,CR12 and the little resistor R30 maintain a voltage "space" between them. If one of those opens, or the pc traces do, then the two polarities are not longer held in control and both sides will go ON full. Fuses blow.
  1. Peavey cs-400 Blowing Fuse
    By barnacle in forum Maintenance, Troubleshooting & Repair
    Last Post: 04-11-2011, 11:13 PM
  2. Peavey CS-800 Power Amp(The Beast is dead!)
    By ripesean in forum Music Electronics
    Last Post: 02-05-2010, 02:17 AM
  3. Peavey Special 130 blowing fuses
    By Steve Casas in forum Maintenance, Troubleshooting & Repair
    Last Post: 10-10-2009, 09:02 PM
  4. Peavey CS-800 Need Help!!
    By mattygeetarross in forum Music Electronics
    Last Post: 04-21-2009, 01:27 AM
  5. peavey cs 800 wiring
    By dmlandula in forum Maintenance, Troubleshooting & Repair
    Last Post: 05-28-2008, 01:41 PM
