Results 1 to 8 of 8
Thread: EZ81, 6CA4, EL84 Question.
    Apr 2010
    Moreno Valley, Ca. 92551
    72
    1. 6CA4/EZ81 Tube. Can I use this tube with Four EL84 instead of a one GZ34.
    2. Can I use Two.
    Strange question I know,but I have wanted to build a matchless or AC30 Style Amp with EZ81 as the rectifier tube.
    PT is 350 - 350 VAC.
    Supporting Member Alex R's Avatar
    Mar 2007
    UK
    1,127
    I know it won't work with one, and will leave the question of running two to someone who knows... but what I would warn against is running a rectifier on the same heater circuit as the rest of the tubes (which may be what is tempting you). These rectifiers are prone to short plate-to-cathode (and heater) when they fail, which has a lot of potential for damage throughout the amp.
    Apr 2010
    72
    Thanks, for the reply, I have experienced that fault with an older EL84 Tube amp with two EL84's and EZ81.
    Capacitater Steve Conner's Avatar
    Glasgow, Scotland
    6,780
    I don't see any reason why running two EZ81s in parallel wouldn't work.
    But yes, EZ81s have the cathode that's supposed to be isolated from the heater, hence that nasty failure mode where the insulation breaks down. If you want to use them, it's best to run them off a separate heater winding that you can connect to the rectifier cathodes.
    Apr 2010
    72
    Steve,
    Sorry that I never got back to this. Any suggestions on how it should be wired or a suggested circuit?
    Senior Member ThermionicScott's Avatar
    Dec 2009
    SW CR IA US NA PE
    463
    You'd need either a PT with two separate 6.3V windings, or an additional filament transformer that just heats the rectifier tube. Failing that, I think the best policy is to stay within the max cathode-to-heater voltage ratings, and to make sure the filament voltage is not too high (additional heat makes the filament insulation more conductive). Using an artificial center tap on the heater winding as opposed to simply grounding the CT would be a good idea as well.
    - Scott
  7. #7
    Dec 2007
    769
    Another choice to consider is the Weber Coppercap. They don't require heater taps and allow greater flexibility in choosing voltage sag and the first filter cap value. I find them very handy for cathode biased amps to adjust the B+.
    Weber Copper Cap Rectifiers
  8. #8
    Senior Hollow State Tech Bruce / Mission Amps's Avatar
    Denver, Colorado
    2,892
    Just use solid state diodes instead of two EZ81s... assuming the 350-0-350 PT has a high voltage center tap like it should, put a 5 watt, 47 ohm to 100 ohm resistor in the center tap lead to ground for a little bit of sag, simulating the effect of a tube rectifier. Not a perfect solution but VERY inexpensive.
    Bruce
    Mission Amps
    Denver, CO. 80022
    www.missionamps.com
    303-955-2412
  1. Rectifiers: EZ81 in place of an EZ80 - is it possible?
    By slidincharlie (Carlo P) in forum Mods & Tweeks
    Last Post: 08-11-2010, 05:49 PM
  2. 5Y3 EZ81?
    By Leif H in forum Tubes (Valves)
    Last Post: 06-11-2010, 11:05 PM
  3. Replies: 0
    Last Post: 11-13-2008, 01:35 AM
  4. Max input filter cap for EZ81?
    By truth_hz in forum Theory & Design
    Last Post: 09-07-2008, 03:10 AM
  5. EZ81- how much can they really take?
    By imaradiostar in forum Theory & Design
    Last Post: 04-21-2008, 04:32 PM
