Results 1 to 18 of 18
Thread: 5e3 Troubleshooting
    Jan 2011
    16
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    5e3 Troubleshooting
    I finished my 2nd 5e3 build and just can't get it going. Initially, only one channel worked. I traced everything, couldn't find it. Pulled the circuit out, re-wired, and now both channels work... Well, in theory. I am hearing signal from my guitar out of 1&2 B&N it just sounds like a bad fuzz pedal. The sound is low volume, but there is input. I tried different power/pre amp tubes and the same thing happened.
    I need some kind and wise elder to talk me through the basics of taking readings. I just got a sweet new meter, but really don't know how to use it correctly.
    I tried to take some readings and fried the 100ohm resistors from the pilot light
    That was dumb. I replaced them, but now I am back to square one.
    I am at the place where I am ready to learn from this frustrating build but I am at the limit of my experience. All of the previous posts have been insightful, just not quite my situation.
    My current theory is that it is either the OT or the Rectifier tube (two things I haven't swapped out). The fact is, before I go replacing stuff I need to learn how to meter. I have done continuity checks on every connection. That was a no-brainer.
    I am using the schematic Mojo provides in their small-parts kit.
    Help!
    0 Not allowed! Not allowed!
    Supporting Member txstrat's Avatar
    Mar 2008
    Germany
    1,262
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    I think it's unlikely to be the OT or recto tube since the amp had worked before (at least one channel).
    It might be a wrong or missing wiring. Could you post some pics of your build?
    To measure your voltages put the black probe of the meter to ground and the red to the spot you want to measure.
    Set the meter right (AC, DC, OHMS).
    Be aware, the voltages in tube amps can KILL you.
    Jan 2011
    16
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    Thanks. Here are some pictures:
ID:	12341Click image for larger version.
ID:	12342Click image for larger version.
    Jan 2011
    16
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    And a few more...
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	12344   Click image for larger version.
ID:	12345   Click image for larger version.
ID:	12346   Click image for larger version.
    Jan 2011
    16
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    Okay, this will sound dumb, but I am measuring DC voltages on the pins of V1-5. Am I attaching the leads to the meter at 10A or CxmA (200mA)? Obviously COM is ground. But what is V Omega? Is that for resistance measurements?
    Also, these measurements on V1-5. Are they taken with the standby switch on or off?
    I know, I know: this is real basic and I should know, but I am trying to be careful and learn!
    Mar 2008
    Germany
    1,262
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    Right, COM is ground (or COMmon). The red one on the right is for Voltage and Ohms (the omega sign stands for ohms). Use the 1000v setting on DC while measuring inside the circuit (after the rectifier). While measuring the transformer leads (before the rectifier) set in on AC. For the heaters you use the AC setting too (you could set it on 20v to get a more exact reading).
    The amp has to be in play mode (stand by in ON position) - otherwise there would be just the heaters voltages on the tube pins.
    Search through this forum to get an idea what the voltages in a 5E3 should read (I've seen several threads with them voltages listed).
    Your build looks quite tidy and on first glance I can't make out anything obviously wrong.
    Do the tubes glow?
    Look for accidentally wrong connections.
    Maybe the shielded wire was too hot soldered and the isolation melted - leading to a short (just a shot in the dark).
    Compare every solder joint with the schematic (make a copy and take a pencil to cross out every checked connection).
    More ideas might come up when you post the voltage readings.
    (maybe you could use alligator clips on your meter probes -to avoid slipping- and switch the std by in ON position when you clipped them in place)
    Good luck and be careful.
  7. #7
    Jan 2011
    16
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    Thanks for the tips. I was able to measure everything. Here are the readings:
    pin: 1 2 3 4 5 6 7 8 9
    V1 12ax7: 208 1.64 3.37------ 206 1.63 3.37
    V2 12ax7: 201 1.54 3.37------ 306 5 3.37
    V3 6v6GT: 3.37 394 379 3.37 26
    V3 6v6GT: 3.37 396 380 3.37 26
    V5 5y3GT: 117 393 392 117
  8. #8
    Jan 2011
    16
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    Sorry, that didn't come out looking as cool as the way I typed it!
  9. #9
    Jan 2011
    16
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    Here it is better organized:
    V1 12ax7:
    Pin 1: 208
    Pin 3: 1.64
    Pins 4-5: 3.37
    Pin 6: 206
    Pin 8: 1.63
    Pin 9: 3.37
    V2 12ax7:
    Pin 1: 201
    Pin 3: 1.54
    Pins 4-5: 3.37
    Pin 6: 306
    Pin 8: 5
    Pin 9: 3.37
    V3 6v6GT:
    Pin 2: 3.37
    Pin 3: 394
    Pin 4: 379
    Pin 7: 3.37
    Pin 8: 26
    V4 6v6GT:
    Pin 2: 3.37
    Pin 3: 396
    Pin 4: 380
    Pin 7: 3.37
    Pin 8: 26
    V5 5y3GT:
    Pin 2: 117
    Pin 4: 393
    Pin 6: 392
    Pin 8: 117
  10. #10
    Jan 2011
    16
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    I just re-measured the Rectifier because 117 ain't right for sure! Here is what I read this time:
    V5 5y3GT:
    Pin 2: 8
    Pin 4: 393
    Pin 6: 392
    Pin 8: 8
    I'm not sure how I got 117 before! Although 117 is a familiar voltage! According to the Mojo transformer schematic, it should be 5v ac.
  11. #11
    Mar 2008
    Germany
    1,262
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    What about pins 3 and 7 on tubes 1 and 2?
  12. #12
    Jan 2011
    16
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    I will have to take a look this afternoon. I was reading a chart that didn't give voltage for pin 7 on tubes 1 & 2 so I didn't measure them. I got that chart off the web and nearly all of the voltages were lower than anything that I was reading.
    Pin 3 was 1.64 on V1 and 1.54 on V2
  13. #13
    Jan 2011
    16
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    Okay, I built a jumper with clips on each end and a 2w 470ohm resister inline to drain the caps. I have read several different approaches here, I was wondering:
    What mV reading is safe? For instance, I connected each cap (positive side), waited, and re-measured. They still don't read 0.00. Right now they read 5.0 mV.
    Should I reconnect them one by one and wait longer until it reads 0.0? Or should I try another method like grounding pin 1 of a pre-amp tube and waiting?
  14. #14
    Jan 2011
    16
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    Here is something that I noticed doing continuity checks. When I ground one probe and then touch the speaker tip, I get the continuity alarm. Is my OT to speaker correct?Click image for larger version.
Name:	OT to Speaker.JPG
  15. #15
    Jan 2011
    16
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    I just finished resistance checks on the input wiring that Loudthud posted in another thread:
    "With power off and no cable plugged in, the grid of the tube (pin 2 or 7) should measure 34K to ground. With an open ended cable plugged into the #1 input you should measure 1.034Meg. With the cable in the #2 input you should measure 68K. Next measure from the end of the cable where it plugs into the guitar. The #1 input should measure 1Meg between tip and ground. The #2 input should measure 136K. Now measure between the tip of the cable and the grid pin on the tube socket. 34K on the #1 input and 68K on the #2 input. Measure both channels."
    Everything checks out in both channels so I think I can rule out the input jack wiring. Any other suggestions?
  16. #16
    Jan 2011
    16
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    Alright! I found that I missed the 1.5K resistor on the tag board. I just forgot it! So I wired it in and it works!!!
    Phew! Thanks for answering my dumb questions and giving me a little confidence to forge ahead.
    Now I need to do some forum research on here to debug it. When I turn the tone pot up all the way it shrieks horribly. Turn it down and it sounds great.
    But that is a HUGE improvement over no volume at all!
  17. #17
    Mar 2008
    Germany
    1,262
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    Great to hear that it works. Well done.
    Regarding the shrieking: if the amp had a negative feedback, I'd say interchange the wires to the power tube plates. But a standard 5E3 don't have a NFB.
    Might be the lead dress.
    Take a wooden stick (chopstick) and move the wires inside the chassis around. Any changes?
    Look if you could shorten the grid wires (of any tube) or move the 1.5K grid stopper resistors (to the power tubes pins 5) from the board directly to the tube sockets.
  18. #18
    Jan 2011
    16
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    I'll have to get into it in the morning. Thanks again!
    I have moved this thread to:
    http://music-electronics-forum.com/t23302/
  1. transistor troubleshooting
    By trem in forum Maintenance, Troubleshooting & Repair
    Last Post: 09-28-2010, 03:17 PM
  2. RAT Troubleshooting
    By ManRay in forum Guitar Effects
    Last Post: 08-11-2010, 01:21 PM
  3. Replies: 7
    Last Post: 06-26-2009, 05:24 AM
  4. Troubleshooting motorboating
    By EETStudent in forum Maintenance, Troubleshooting & Repair
    Last Post: 04-23-2008, 10:17 PM
  5. 6g15 troubleshooting
    By joelw in forum Guitar Effects
    Last Post: 03-25-2008, 05:42 AM
Tags for this Thread
