Results 1 to 19 of 19
Thread: Strange 5AR4 "Problem"
    Supporting Member Zer09's Avatar
    May 2010
    NJ
    78
    I have a 5e8a twin that I built with the ability to use 6l6's or el34's. When I use el34's I use a single gz34 rectifier. I've had no issies with this setup. I prefer the sound of 5881's (real 5881's, not the sovtek wxt) and I was switching back the other day. Just for the heck of it I decided to test the tubes that I pulled. The rectifier is a fat bottle Sylvania 5ar4. When I tested it the heaters lit up but under test only one plate was allowing current to flow. The other tested completely dead. This was tested on a Weston 981 tester. I have 2 of these. It tested dead on the second one as well. The result was confirmed again on an EICO 666 emissions tester that I have. I put the tubes back in the amp and they work fine.
    Is it possible that one half of a 5ar4 is supporting 2 el34's @ 420v @41ma and doing so in a stable manner? I find this hard to believe. Or is something just preventing this tube from being tested correctly?
    Noodle of Reality Steve Conner's Avatar
    Glasgow, Scotland
    7,251
    Yes it is possible. The remaining good half of the tube will function as a half wave rectifier, so you'll still get power. But, if you tested the amp's output power you'd find it was low because the B+ would sag too much under load. Also the PT may well run hotter and make a different, rough buzzing noise than it would with a good rectifier.
    Aug 2010
    159
    Lucky it didn't develop an internal short! I'd really recommend that you install a couple of diodes in series with the tube rectifier. That trick from RG has saved my ass a couple of times over the years.
    May 2010
    NJ
    78
    Thanks for both of your posts. Chucked the 5ar4. I'm going back to back to 5881's anyway. As for diodes in series with the rectifier plates, I'm not really worried about that. I have HT fuses to protect my transformers but in 30+ years of playing I've never had one fail. Adding diodes would just push my B+ too high for 5881's. There are times though when I'm gigging frequently that I'll stick a weber copper cap in an amp just to avoid the physical abuse to a $100 Mullard. But the advice is always appreciated.
    Supporting Member
    Staffordshire UK
    3,195
    'Adding diodes would just push my B+ too high for 5881's'
    The diode greekie is referring to are in series with the tube rectifier.
    They would only ever raise the voltage if the tube rectifier develops a short.
    Pete.
    Junior Member Greg-M's Avatar
    Nov 2011
    Poulsbo, WA
    6
    Like this....
    Added diodes to my 200S amp (same as a Dynaco). It's a happy camper.
  7. #7
    Jun 2006
    California, USA
    3,385
    Nice illustration drawing. Reminds me of the old Heathkit construction illustrations.
  8. #8
    Nov 2011
    Poulsbo, WA
    6
    I wish I could take credit for the drawing. I got it off of a Dynaco forum
  9. #9
    May 2010
    NJ
    78
    OK. What am I missing? The drawing above shows the PT secondaries connecting to the diodes using unused rectifier tube socket pins. The other end of the diodes connect to the plates. So the ac is rectified by the diodes before it ever gets to the plates. How does this not increase the b+ over just a tube rectifier? I understand that when the tube fails you lose the voltage drop across it. But aren't you still starting with a higher b+ before it fails?
  10. #10
    Supporting Member jmaf's Avatar
    Apr 2009
    BSB-DF
    1,268
    Quote Originally Posted by Zer09 View Post
    The maximum +B is the peak of the AC wave right before the silicon diode anodes. There is no way that adding a passive component there would increase +B from 1/2 p-p AC. So adding a silicon diode does not increase the voltage, it in fact decreases it a diode drop.
    Edit: And when a rectifier fails, it often arcs from anode to cathode, it's a short, you don't lose only the voltage drop across the tube, you lose all voltage in fact, blown fuse, magic smoke.
    "Tell them I said something." - Pancho Villa's last words
    Tube Amplifier Resources in Brazil: Valvulados.com
  11. #11
    Supporting Member
    Staffordshire UK
    3,195
    The 1N4007 1kV rating is likely to be marginal or insufficient for many instances of this application.
  12. #12
    Nov 2011
    Poulsbo, WA
    6
    I put two in parallel at each point, just to make sure
  13. #13
    Apr 2009
    BSB-DF
    1,268
    Quote Originally Posted by Greg-M View Post
    Add them in series. You don't need the current there, but the peak reverse voltages.
  14. #14
    May 2010
    NJ
    78
    Quote Originally Posted by jmaf View Post
    The last part was in reference to what happens when a rectifier tube fails with diode backups.
    When I refer to b+ I am referring to the dc side of the rectifier, and the subsequent plate voltage on the 5881 tubes. So you are telling me that putting diodes in series with a tube rectifier is not going to increase the dc voltage coming out of the rectifier tube? I mean according to this calculator PT Current Draw there is a 40-50v increase in rectified voltage going from 5u4 to diodes. What becomes of that difference when you put a tube after the diodes? This is what I'm missing and that's what concerns me. I don't want to end up with 500v on the plates os my power tubes.
  15. #15
    Supporting Member
    Staffordshire UK
    3,195
    The tube diode drops 40V (or whatever) and the Si diode drops ~0.6V. The 2 are in series, with the same arrangement each leg of the B+ winding. Therefore total voltage drop is 40.6V.
    The characteristics of the tube diode massively dominate those of the Si diode, in terms of volt drop, internal resistance, switching time; such that for normal operation, the Si diode may as well not be there.
    However if the tube diode shorts then the total volt drop reduces to 0.6V, the Si diode takes over and prevents a massive Vac being fed to the reservoir cap etc, and keeps the show on the road, allbeit with hotter operating conditions.
    Pete.
  16. #16
    Apr 2009
    BSB-DF
    1,268
    Think of the tube rectifier as a resistor after the silicon diode. When you add a tube after the diode, it drops voltage, like every resistor does when there's current through it.
    If you substitute a tube for a diode, and remove the tube, you remove that "virtual" resistor. When you put the tube in, that's how it "steals" voltage which I believe is your question?
  17. #17
    Dec 2007
    932
    I bought a used amp for cheap and it's main issue was that it would pop the fuse when you turned it on. It had a Mullard GZ34 that was shorted. It was likely an original rectifier tube in the fifty year old amp. Now it runs happily on a copper cap.
  18. #18
    May 2010
    NJ
    78
    That's the bit of information I needed. The tube resistance dominates the diode. All makes sense to me. It just sounded contrary to everything I've learned about rectifiers to this point. I'm actually going to go back and do it to all of my amps with tube rectifiers.
    Now, when I did my first build, an ab763 deluxe reverb, I had a tech sort of guiding me through it via email support. he had me add 1.5kv, 1.5amp diodes in a similar manner with one on each plate. Would those be sufficient? I think I still have a bunch around but have plenty of 1n4007's as well. He was concerned about new production rectifiers and I hadn't started using Mullards yet. Like I said in the first post, I never had one fail but the peace of mind would be well worth the minimal effort. I'd be lying if I didn't say that rectifier tube failure has entered my mind at least once during every gig I've ever played.
  19. #19
    Dec 2007
    932
    Yes, one 1.5kv 1.5 amp diode on each plate should work fine as protection for tube rectifier shorts. If you run out of those diodes, you could use 1n4007 or 1n5408 (3-amp).
  1. "Blows Fuses" and "Is my transformer dead?"
    By R.G. in forum Maintenance, Troubleshooting & Repair
    Last Post: 09-14-2012, 04:03 AM
  2. Replies: 9
    Last Post: 02-24-2011, 04:21 AM
  3. Peavey Delta Blues - No Sound - All Tubes Glow - Powered "On", Made a "Hum", and died
    By Renegade44 in forum Maintenance, Troubleshooting & Repair
    Last Post: 12-15-2009, 06:24 AM
  4. Crate XT120R "high" pot problem
    By lowell in forum Maintenance, Troubleshooting & Repair
    Last Post: 06-23-2008, 09:41 AM
  5. Replies: 7
    Last Post: 10-20-2007, 02:53 PM
