Results 1 to 11 of 11
Thread: Keeping a Gretsch in Tune
    Mar 2012
    Western Pennsylvania
    9
    I have both a '67 Tennessean and a '67 Country Gent. Is there some secret to keeping these tuned properly without replacing the tuners? Even without touching the Bigsby, they both need to be tuned too often. Nature of the beast?
    Thanks.
    Apr 2008
    Oceanside, NY
    1,642
    You really should employ locking tuners, but if you don't want to, try these things first. You will need some Super Lube Teflon oil for this:
    1- At least 4-6 string wraps around each tuner post.
    2- A drop of Super Lube oil in each nut slot (string contact/friction point)
    3- A drop of Super Lube on the top of each saddle (string contact/friction point)
    4- While not strung up, lube the moving arm axle points
    5- Replace the old trem spring, as it might have collapsed and has lost resiliency. Tuning stability all depends on this one spring, which counterbalances all of the string tension.
    If your strings are well-anchored at the posts, and all string and other friction points are lubed to minimize drag, you have a better chance of staying in tune.
    John R. Frondelli
    "Mediocre is the new 'Good' "
    Little Rock, AR
    96
    I've had a '67 tennessean since '67) Remember that the bridge floats and does not compensate. You must measure the distance from the zero fret / nut each time you change strings. Being out a little will throw it out of tune. It is the nature of this instrument to give tuning problems. You can minimize the problem with lube but not get rid of it. It helps to play near the nut. You could disable the trem by replaceing the spring with a solid tube to disable it. That will help.
    Old Timer soundguruman's Avatar
    Jul 2011
    California
    1,682
    When you put on the string, lock it over itself at the tuner, tune it to pitch
    pull on the string to stretch it out, then tune it back to pitch
    repeating this for each string over and over, eventually, the string will stay in pitch...
    However with a floating bridge tremolo, there are inherent problems...like a stratocaster.
    Mar 2012
    9
    Appreciate the advice. I'll try. Let you know. I have a '72 Strat. Seems to stay in tune OK, though.
    Mar 2012
    9
    I noticed that there are two spring sizes....7/8" and 1 inch. Which do you recommend?
  7. #7
    Jul 2011
    California
    1,682
    Well obviously, if the bridge floats, when you tighten one string you can expect to loosen the others.
    But repeating tuning and stretching the strings, it will even out after a few tries, eventually.
    I just takes that initial getting used to, that is different from a fixed bridge.
  8. #8
    riz
    riz is offline
    May 2010
    253
    Go to Gretschpages and search your topic. Endless threads on the subject. I keep my Gretsch guitars in tune every day... with old tuners, and I am a heavy Bigsby user. I greatly prefer the 1" spring.
  9. #9
    2,301
    Quote Originally Posted by riz View Post
    I may be wrong but the different spring sizes/heights may be for the different Bigsby formats. The B3 format has just the one roller for anchoring the strings. The other formats have dual rollers, implementing an under and over arrangement for the strings before reaching the bridge. The two likely require different tensions in the spring.
  10. #10
    Mar 2012
    9
    Thanks for all the suggestions. Never saw Gretsch Pages before...great find!
  11. #11
    riz
    riz is offline
    May 2010
    253
    Quote Originally Posted by Mark Hammer View Post
    The springs set the height of the handle, and the feel.
    Don't believe everything you think. Beware of Rottweiler. Search engines are free.
  1. That Reverb Thing. Keeping it simple.
    By ivey in forum Build Your Amp
    Last Post: 04-01-2011, 09:00 PM
  2. Amp tune -up?
    By Unisawyer in forum Maintenance, Troubleshooting & Repair
    Last Post: 01-31-2010, 05:18 AM
  3. Always going out of tune
    By jak0lantern01 in forum Guitar Tech
    Last Post: 07-26-2008, 08:35 PM
  4. keeping bucker bobbins mint....
    By Possum in forum Pickup Makers
    Last Post: 06-17-2008, 02:18 AM
  5. Engl Fireball - keeping the basic stuff
    By blackwood in forum Theory & Design
    Last Post: 10-03-2006, 01:09 PM
