Results 1 to 2 of 2
Thread: Marshall 1959SLP Low Bias readings. Help !
    Jul 2007
    1
    Hello from Italy, I have a problem with my 1959SLP Head
    All seem OK but I can't reach the correct bias values with VR1
    I can reach max 20mA on each EL34, and this is too low.
    I checked the tubes, filter caps, bias supply, grid resistences, catode to ground. All seems OK.
    The palte voltage is 455 Volts and the bias on the grid is -45 Volts
    I hope that you can give me some suggestion.
    Thanks,
    Nye
    Old Timer Amp Kat's Avatar
    Jul 2006
    Baton Rouge,LA
    1,440
    See if R28 is a 56k resistor and try changing that to 33k I think that will drop the current but it may be the other way but I think that is the resistor.
    KB
  1. Marshall JTM 30 Bias Adjustment
    By kramps in forum Maintenance, Troubleshooting & Repair
    Last Post: 04-25-2011, 07:28 PM
  2. Replies: 6
    Last Post: 01-22-2008, 07:05 PM
  3. Marshall TSL 1000 high bias voltage - help
    By sonic_tooth in forum Maintenance, Troubleshooting & Repair
    Last Post: 10-13-2006, 05:48 PM
  4. Marshall jcm2000 dsl 100 Bias low
    By pbdog in forum Maintenance, Troubleshooting & Repair
    Last Post: 09-28-2006, 01:36 AM
  5. Marshall 1959SLP Problems - Please Help
    By Peter Nerves in forum Maintenance, Troubleshooting & Repair
    Last Post: 09-17-2006, 04:57 PM
